SIP speedo problem
SIP speedo problem
Postby Stesjh » Thu May 28, 2020 6:38 pm
After a bit of advice, have a new SIP speedo with fuel sensor, everything was working fine till the other day when the fuel warning came on. Checked fuel - nearly full, however, refuelled to the top. Now the Fuel warning comes on and off every few seconds. Has anyone else had this problem and got a solution please?
Stesjh
Re: SIP speedo problem
Postby Toddy » Thu May 28, 2020 9:41 pm
Is the float sticking on the petrol tap inside the tank ( if it’s that type of sensor) ethanol can effect them or been bent slightly when fitted ?
Postby Stesjh » Thu May 28, 2020 11:09 pm
Thanks . I’ll double check tomorrow
Stesjh
