polishing ports
polishing ports
Postby garynonnah » Tue Sep 09, 2014 10:02 pm
Hi guys....just stripped new sil 200 engine to change bearings/seal /crank all going well as not done this before.
but question is....is it worth polishing out ports in the barrel, and any other suggestions ....
cheers all.
garynonnah
Re: polishing ports
Postby Dimitrios_231 » Tue Sep 09, 2014 10:44 pm
SIL casting is very rough and hard.
You can match the ports to the the manifolds and smooth them to aid the flow.
You don't need to polish the inlet,polish only the exhaust port.
I also had an imperfection at the exhaust port.A small bit at the edge was broken.I had to raise the port to smooth the flow.
Dimitrios_231
Re: polishing ports
Postby garynonnah » Wed Sep 10, 2014 6:57 pm
cheers fella....appy days
garynonnah
Re: polishing ports
Postby Dimitrios_231 » Thu Sep 11, 2014 7:16 am
I found some pics from another SIL that I've done.
Dimitrios_231
Re: polishing ports
Postby Dimitrios_231 » Sun Sep 14, 2014 12:37 pm
It won't harm if you also smooth (not enlarge) the transfer feeds at the base.
Dimitrios_231
Re: polishing ports
Postby garynonnah » Sun Sep 14, 2014 9:39 pm
thats cool....will let you know how i get on.
garynonnah
Re: polishing ports
Postby Dimitrios_231 » Mon Sep 15, 2014 2:40 pm
Just to clarify,
cleaning and matching the ports only,is the minimum work that can be done without affecting port timing etc.
It doesn't improve by any means the power of an engine but it helps for a better running.
Dimitrios_231
Users browsing this forum: Baidu [Spider], Google [Bot] and 70 guests
