Which gearbox?
Which gearbox?
Postby dickie » Sun Mar 29, 2020 2:39 pm
I'm building a RT230 reed motor. It will be run with avanti ex box clubman and phbh30. So a broad spread of power.
It's not a race bike, nor do I do huge miles, mostly local country roads with my mate on his Suzuki gs850 (he's a sedate rider) for breakfast, then home. I very rarely ride more than, say 60 miles in a day.
There are 2 obvious choices for gearbox. Indian GP200 or AF 5 speed. The 5 speed seems to be the obvious choice but with a reed, slightly long stroke crank and clubman power curve, is it simply more expensive for no real world gain? I can see the advantages for peaky motors, especially if used for touring, but neither apply to me.
Experience or thoughts please?
Re: Which gearbox?
Postby St George » Sun Mar 29, 2020 3:34 pm
In April's Scootering page 108, there is a write up on a BSSO Proddy Engine strip down. There was nothing derogatory about the SIL GP 200 gearbox in this interesting article. I have had two GP 200 gear boxes and have never had problems.
St George
Re: Which gearbox?
Postby ULC Soulagent » Sun Mar 29, 2020 4:01 pm
I run neither in my engines so have no experience with them, out of my 5 Jet200 engines that I have ( 3 Rt230 reedvalved, 2 have sx200 gearbox 15/46 and the other one has an Mb 5speed) the other two engines have Ts1230 running sx200 15/46. All 5 engines are a pleasure too ride setup for touring. I’d go for the gp considering what ur using it for :)
Re: Which gearbox?
Postby Rich Oswald » Sun Mar 29, 2020 5:20 pm
Indian GP200 with a 19 front sprocket.
Re: Which gearbox?
Postby dickie » Sun Mar 29, 2020 5:37 pm
Thanks gents. That's what I was hoping you'd say. :D
And I'll go with 19 x 47 rich.
Too easy to get sucked into buying something you don't really need.
Re: Which gearbox?
Postby Tractorman » Sun Mar 29, 2020 7:11 pm
I have using an Indian GP200 gearbox in the sidecar scooter for a few years now without problems.
Re: Which gearbox?
Postby Fast n Furious » Mon Mar 30, 2020 3:24 am
It can be pot luck with Indian gearboxes in my experience. Some batches are ok, others are too hard or too soft.
Re: Which gearbox?
Postby Jeff t » Thu Apr 02, 2020 2:31 pm
Interesting reading, I have an Imola small block with an Indian GP150 gearbox and looking at options looks like from what I have read that an Li150 is probably the best set up but finding one looks nigh impossible. Couple of new options including the Casa 4 speed anyone experience of this box?
Jeff t
Re: Which gearbox?
Postby rossclark » Thu Apr 02, 2020 11:01 pm
There's at least 3 on eBay right now
Re: Which gearbox?
Postby dickie » Fri Apr 03, 2020 7:33 am
Jeff t wrote:Interesting reading, I have an Imola small block with an Indian GP150 gearbox and looking at options looks like from what I have read that an Li150 is probably the best set up but finding one looks nigh impossible. Couple of new options including the Casa 4 speed anyone experience of this box?
I'd imagine that box will be horrible on an imola, but maybe depends on your pipe too. I have one in my tuned 175 with expansion and I hate it. There's al LI150 box on my shelf for it when I get the time.
After much deliberation, I bought an AF 4 speed close ratio box. Seems a good balance of performance vs price and well proven. Of course I'd have liked a 5 speed, but at an extra £350 ish, including gear change, I just couldn't justify it for the type of riding I do.
Re: Which gearbox?
Postby Jeff t » Fri Apr 03, 2020 8:44 am
Yeah it is pretty bad to ride as it is, the ones on ebay I hadn't seen the Spanish one for sale so missed that and the only other I could see was the one at £79 and if I am honest was unsure if it would be ok on a tuned engine probably jumping to conclusions on where its made and possibly how good it is. Think its a toss up between the Spanish LI and the AF close ration (also on ebay)
Jeff t
Re: Which gearbox?
Postby dickie » Fri Apr 03, 2020 10:37 am
Jeff t wrote:Yeah it is pretty bad to ride as it is, the ones on ebay I hadn't seen the Spanish one for sale so missed that and the only other I could see was the one at £79 and if I am honest was unsure if it would be ok on a tuned engine probably jumping to conclusions on where its made and possibly how good it is. Think its a toss up between the Spanish LI and the AF close ration (also on ebay)
You can get af close ratio for £100 from India but there'll be an extra £20 duty to pay. I've had loose gears from india that were fine, but I recently fitted two first gears which just crumbled. Really poor quality, way too hard. One lasted around 20 starts before it had lost around 1/3 of its kickstart teeth.
So I bought direct from AF. It's likely that they have some degree of input on quality control and also seems a little underhand to buy direct from India when they've done the development work. It was £195 delivered. Seems to tick all the boxes for me as i don't really enjoy riding a lambretta beyond 70mph; that's what my Triumph is for.
Re: Which gearbox?
Postby Rich Oswald » Fri Apr 03, 2020 11:31 am
I would not recommend the Spanish LI box!
Re: Which gearbox?
Postby dscscotty » Fri Apr 03, 2020 1:31 pm
There's 2 versions of Spanish Box Rich, one(early) has same ratio's as Italian, regarding the AF close ratio 4 speed, we run them in our Grp 4 race motors, with 0 breakages last season, also ran one in our endurance race winning motor.
Re: Which gearbox?
Postby dickie » Fri Apr 03, 2020 4:29 pm
dscscotty wrote:There's 2 versions of Spanish Box Rich, one(early) has same ratio's as Italian, regarding the AF close ratio 4 speed, we run them in our Grp 4 race motors, with 0 breakages last season, also ran one in our endurance race winning motor.
Yes, I should probably have said that another major factor in my decision was you telling me how much confidence you have in them.
If they can stand up to race abuse, I'm sure they'll cope with my jaunts out looking for bacon and black pudding.
Re: Which gearbox?
Postby Lammer205 » Fri Apr 03, 2020 8:44 pm
Just on the Afclose ratio box i had one then lost teeth of the cluster purchased a new one from Af but when its assembled it sounds very rough like a grinding sound anyone noticed this with this box When assembled? ThanxLammer205
Lammer205
Re: Which gearbox?
Postby Rich Oswald » Fri Apr 03, 2020 9:58 pm
Didn't know that Darren, I was just going by my experience of one I had.
Re: Which gearbox?
Postby Ivor the engine » Tue Nov 01, 2022 8:42 am
Hi All,
Regarding the AF close ratio gearbox, what sprocket (front / rear) set up would be best suited for this, running a stage 4 top end and 22m carb?
I've done some digging and there is mention of a 19x46, but with a diffrent high powered top end.
Any thoughts, feedback or experiences are welcome.
Thanks,
Ivor
Ivor the engine
