ts1 225 piston gudgeon pin
Postby al pushpak » Thu Sep 04, 2014 8:47 pm
Hi I'm after a new gudgeon pin for my ts 225 piston, af's are out of stock so wondered if anyone knows of any other stockists or of an alternative pin with the same dimensions , piston is the std asso type. many thanks for any info Al ;)
al pushpak
Re: ts1 225 piston gudgeon pin
Postby Knowledge » Thu Sep 04, 2014 10:13 pm
In the past, I have shortened over-long grudge on pins by putting the pin in a drill chuck and spinning the pin whilst machining the end with an angle grinder.
It sounds brutal, but it is surprisingly effect. First, you need to find an over-long pin.
Someone clever will be along in a minute with a sensible suggestion.
Postby Scooterlam » Thu Sep 04, 2014 11:12 pm
Put a wanted up, someone will be bound to have one.
Scooterlam
Postby hullygully » Fri Sep 26, 2014 1:55 pm
I'll give you 1 (ooer :lol: ) if you're on the 4 nations or @ brid?
Postby al pushpak » Fri Sep 26, 2014 5:13 pm
Thanks for the tempting offer hullygully :) but I've got one sorted now ;) thanks again Al
al pushpak
Users browsing this forum: Baidu [Spider], Google [Bot] and 70 guests
