by Simon ELC » Fri Aug 23, 2019 8:59 pm
Anybody using an Indian GP200 gearbox but with a 35 tooth 4th gear from a Vijay MK1?
I've just removed this combo from a 'Nammer' which has been running ok for ages. Is it likely to break?
Simon ELC
by HxPaul » Sat Aug 24, 2019 8:31 am
You may have a GP150 (Vijai Super) gearbox,they're exactly the same as GP200 except for the 4TH gear.Check your gear cluster.
by Simon ELC » Sat Aug 24, 2019 9:24 pm
Thanks Paul. I originally thought it was a Mk1 Vijay 150 box but I've counted the teeth about 10 times to be sure and the cluster is definitely from a GP200.
Simon ELC
