engine casing getting hot.
Postby brownymozzey » Mon Jun 24, 2019 8:19 pm
Need a bit help monza225 30mm delorto and bgm clubman, engine casing getting really hot checked internals nothing rubbing, someone said if the exhaust is touching the casing the heat would transfer to casings, Indian large fin flywheel, even doing it at 30mph over 2 miles had it on mick abbeys dyno the fuel temperature at the head is spot on, any ideas, cheers.
brownymozzey
Re: engine casing getting hot.
Postby MickYork » Mon Jun 24, 2019 9:25 pm
is oil breather clear ?
Postby brownymozzey » Tue Jun 25, 2019 5:38 am
Yes , got my head done in,
brownymozzey
Postby dscscotty » Tue Jun 25, 2019 7:08 am
You say you took it to Mick Abbey's where are you based?
Postby ULC Soulagent » Tue Jun 25, 2019 8:00 am
I thought the engine casings are supposed too act as a heat sink :?
Postby brownymozzey » Tue Jun 25, 2019 11:48 am
Scotty it's browny from South shields
brownymozzey
