Rb 250 casing
Hi all, I'm asking for a friend. Does the engine casing need modification at the crankcase opening ? Or anywhere else. Thanks.
https://ilambretta.co.uk/forum/
dscscotty wrote:yes the crankcase mouth needs opening as the 250 has a larger spigot, AF's do this for around-£20-£30ish
Thackers wrote:Hi all, I'm asking for a friend. Does the engine casing need modification at the crankcase opening ? Or anywhere else. Thanks.
