Ts1 225 phbh carb jetting for Ron Moss ex-box clubman
Postby al pushpak » Sun Apr 28, 2019 1:46 pm
Hi, just trying to sort my jetting for the above set-up & hopefully someone can point me in right direction jetting wise so I can get something like. current set-up is 30mm phbh dellorto with breath sweet filter 300 float valve jet, 145 main , 55 pilot, x13 needle 2nd clip from top & av 268 atomisor runs clean through the range with no 4 stroking. thanks for any info ;)
al pushpak
Re: Ts1 225 phbh carb jetting for Ron Moss ex-box clubman
Postby ULC Soulagent » Sun Apr 28, 2019 1:56 pm
If its running clean through the Rev range without 4 stroking then I’d say you more have hit it spot on ;)
