Recessed cylinder head
Posted:
Mon Feb 04, 2019 3:20 pm
by Fred
Hello all, I need a recessed head for a 66.5mm lambretta piston. Has anyone had one done? And who did it? Thanks Fred
Re: Recessed cylinder head
Posted:
Tue Feb 05, 2019 2:59 pm
by Knowledge
Are you saying that your piston pokes out the top of the barrel, and so you need a recess in the head so the piston doesn't hit it?
Or do you mean that the head pokes into the barrel, in order to centralise over the bore (like recent Mugello heads)?
Posted:
Tue Feb 05, 2019 6:15 pm
by Fred
Sorry should've been more explicit. I need the combustion chamber to drop into the bore 1.5 to 2mm
Thanks fred
Posted:
Tue Feb 05, 2019 8:03 pm
by Scooterdude
Check out the BGM/RT heads, yes they do an 8 bolt version that comes with the kit but they also do a standard 4 bolt pattern.
Posted:
Tue Feb 05, 2019 8:40 pm
by Fred
Dropped only available at 70mm for 200 stud spacing
Posted:
Tue Feb 05, 2019 9:42 pm
by shane BBoys
Fred wrote:Sorry should've been more explicit. I need the combustion chamber to drop into the bore 1.5 to 2mm
Thanks fred
WHY?
Is it not the barrel that needs to be lowered?.
Posted:
Tue Feb 05, 2019 9:59 pm
by Fred
I could shorten the barrel. But I'd rather do it this way to set up port timings.
Posted:
Tue Feb 05, 2019 10:31 pm
by dscscotty
Where you located?
Posted:
Wed Feb 06, 2019 9:45 am
by Fred
Rotherham
Posted:
Wed Feb 06, 2019 9:46 am
by Fred
Cam lam do recessed heads for the mugello. Is the mugello piston the same profile?
Posted:
Wed Feb 06, 2019 11:57 am
by dscscotty
Do you wear glasses?
Posted:
Wed Feb 06, 2019 3:25 pm
by Fred
Yes I do Scotty. I've used a different top end on this casing now. It's a casing with big transfers and a boost port. I never got a cylinder done to match. It had that much welding, I had to get base and mag faces skimmed. I didn't want to bin the casing. So I've used packers to block the welded ports. I don't know how this will affect running, as it's an experiment. I've now fitted an old dj 205, and it set up fine.
Posted:
Thu Feb 07, 2019 12:15 am
by Knowledge
Robbospeed sell recessed heads, for both small block and large block engine spacing.
They are much heavier, and therefore a better heat sink than a standard head.
Posted:
Thu Feb 07, 2019 8:40 am
by dscscotty
Hi Fred, if you send the head to me I can get that done for you,
Posted:
Thu Feb 07, 2019 3:53 pm
by Fred
Pm sent, thanks fred
