Recessed cylinder head
Postby Fred » Mon Feb 04, 2019 3:20 pm
Hello all, I need a recessed head for a 66.5mm lambretta piston. Has anyone had one done? And who did it? Thanks Fred
Fred
Re: Recessed cylinder head
Postby Knowledge » Tue Feb 05, 2019 2:59 pm
Are you saying that your piston pokes out the top of the barrel, and so you need a recess in the head so the piston doesn't hit it?
Or do you mean that the head pokes into the barrel, in order to centralise over the bore (like recent Mugello heads)?
Postby Fred » Tue Feb 05, 2019 6:15 pm
Sorry should've been more explicit. I need the combustion chamber to drop into the bore 1.5 to 2mm
Thanks fred
Fred
Postby Scooterdude » Tue Feb 05, 2019 8:03 pm
Check out the BGM/RT heads, yes they do an 8 bolt version that comes with the kit but they also do a standard 4 bolt pattern.
Scooterdude
Postby Fred » Tue Feb 05, 2019 8:40 pm
Dropped only available at 70mm for 200 stud spacing
Fred
Postby shane BBoys » Tue Feb 05, 2019 9:42 pm
Fred wrote:Sorry should've been more explicit. I need the combustion chamber to drop into the bore 1.5 to 2mm
Thanks fred
WHY?
Is it not the barrel that needs to be lowered?.
shane BBoys
Postby Fred » Tue Feb 05, 2019 9:59 pm
I could shorten the barrel. But I'd rather do it this way to set up port timings.
Fred
Postby dscscotty » Tue Feb 05, 2019 10:31 pm
Where you located?
Postby Fred » Wed Feb 06, 2019 9:45 am
Rotherham
Fred
Postby Fred » Wed Feb 06, 2019 9:46 am
Cam lam do recessed heads for the mugello. Is the mugello piston the same profile?
Fred
Postby dscscotty » Wed Feb 06, 2019 11:57 am
Do you wear glasses?
Postby Fred » Wed Feb 06, 2019 3:25 pm
Yes I do Scotty. I've used a different top end on this casing now. It's a casing with big transfers and a boost port. I never got a cylinder done to match. It had that much welding, I had to get base and mag faces skimmed. I didn't want to bin the casing. So I've used packers to block the welded ports. I don't know how this will affect running, as it's an experiment. I've now fitted an old dj 205, and it set up fine.
Fred
Postby Knowledge » Thu Feb 07, 2019 12:15 am
Robbospeed sell recessed heads, for both small block and large block engine spacing.
They are much heavier, and therefore a better heat sink than a standard head.
Postby dscscotty » Thu Feb 07, 2019 8:40 am
Hi Fred, if you send the head to me I can get that done for you,
Postby Fred » Thu Feb 07, 2019 3:53 pm
Pm sent, thanks fred
Fred
