which exaust
which exaust
Postby betty2015 » Sat Feb 02, 2019 9:51 pm
which exhaust would you recommend using using a 5mm packer plate
thanks
betty2015
Re: which exaust
Postby Norrie Bodge » Sat Feb 02, 2019 10:19 pm
betty2015 wrote:which exhaust would you recommend using using a 5mm packer plate
thanks
A bit more info needed mate
What’s your full setup?
Norrie Bodge
Re: which exaust
Postby betty2015 » Sat Feb 02, 2019 11:25 pm
186 muggy lth reed valve 115 yam rod
cheers
betty2015
Re: which exaust
Postby missing lynx » Sun Feb 03, 2019 2:33 pm
What ever exhaust you use the brackets will need some feteling an expansion box doesn't have the bracket onto the underside of the engine and most have more adjustments that a clubman style
Re: which exaust
Postby Norrie Bodge » Sun Feb 03, 2019 4:30 pm
If it’s an expansion you wanting
Something like a JL3 or NK road
be good all rounders
Norrie Bodge
