Reedspeed rear shock
Postby steve chapman » Sun Dec 30, 2018 4:57 pm
I've just put one of the reedspeed rear shocks on my gp , when I push down on my seat and let go , I get a clonk from
The shock , I've tried adjusting the spring but dosnt seem to make any difference, I put my old shock back on and it dosnt do it , any ideas ? Or has anyone had the same problem , thanks steve
steve chapman
Re: Reedspeed rear shock
Postby ULC Soulagent » Sun Dec 30, 2018 5:37 pm
Is there anything catching on the shock?
Could be the shock is topping out which usually means the shock has knackered internals
Postby bamrattle » Tue Jan 01, 2019 9:31 am
Im guessing its an adjustable 1 (you dont say) if so it sounds like you need to adjust the compression/rebound.
bamrattle
Postby trotsky » Tue Jan 01, 2019 10:55 am
Hi,
Just a thought. Is it catching the mudguard on compression/rebound? Check to see if it's wider than your standard one, try some washers to move it away from the mudguard & see if stops it.
Steve.
trotsky
Postby steve chapman » Tue Jan 01, 2019 1:12 pm
Thanks for your replies , first of all must apologise as it's a protech shocker and not a reedspeed one , it defernatly isn't catching on anything as I have got spacer washers at the back , I'm sure it is the shocker topping out , so have decided to send it back to the supplier, will see what they have to say , thanks steve
steve chapman
