58 x 116 or 60 x 115
Postby corrado » Mon Dec 17, 2018 4:55 pm
I can't quite get my head around if base and head gaskets would stay the same using both of these cranks. Kit is designed to use 58 x 116. The 60 crank pushes the piston 1mm higher and pulls it 1mm lower but is that cancelled out by using the 1mm shorter rod?
corrado
Re: 58 x 116 or 60 x 115
Postby dickie » Mon Dec 17, 2018 7:44 pm
If you use exactly the same packers and head gaskets, it will be the same at TDC, but will be 2mm lower ag BDC.
The crank will pull it 1mm further down and the shorter rod will take 1mm more off at BDC.
You're right about TDC.
Postby dscscotty » Mon Dec 17, 2018 10:03 pm
Also keep an eye on your port durations cos the 60x115 will increase them considerably over the 58x116
Postby corrado » Mon Dec 17, 2018 10:08 pm
Thanks chaps, I'll stick with the 58 x 116 then, I figured it wouldn't be so simple.
corrado
