anti dive kit ?
anti dive kit ?
Postby steve chapman » Sun Aug 24, 2014 2:58 pm
looking at putting an andi dive kit on my scoot , i have a scoot rs disc and dont want to weld a bracket on
any ideas would be good , thanks steve
steve chapman
Re: anti dive kit ?
Postby Mike-bristol » Sun Aug 24, 2014 3:09 pm
The ScootRS one is bolt on.
I was thinkinf about this myself.
Mike-bristol
Re: anti dive kit ?
Postby coaster » Sun Aug 24, 2014 3:25 pm
Bolt on is fine and will allow you to position the bracket to get the angle spot on, as close to a parallelogram as possible really. I did that with mine and there is a slight amount of dip under braking to give some feel.
Re: anti dive kit ?
Postby Dimitrios_231 » Sun Aug 24, 2014 3:44 pm
If the bracket is bolted higher ,it gives a stiff brake feeling.
If you bolt it lower,it gives the slight amount of dip that coaster says.
Try it and see what suits you better.
This is the very stiff set up.
Dimitrios_231
Re: anti dive kit ?
Postby corrado » Thu Aug 28, 2014 5:30 pm
This is the conversion kit to upgrade your scootrs hydraulic disc brake into anti dive.
The Black bar is to weld onto the fork leg in place of the clamp, though I'ver never seen one fitted where they've used the weld on bracket so I presume that clamp stays put once it's tight?
corrado
Re: anti dive kit ?
Postby gp200ts1 » Thu Aug 28, 2014 9:32 pm
the weld on one is great once you've decided where you want it. I found that the bolt on one interferes with some aftermarket dampers
gp200ts1
Re: anti dive kit ?
Postby Rich Oswald » Thu Aug 28, 2014 10:23 pm
gp200ts1 wrote:the weld on one is great once you've decided where you want it. I found that the bolt on one interferes with some aftermarket dampers
Do you mean it does not fit with some dampers as it cant interfere with the damper once it is on as the dampers themselves do not move?
Re: anti dive kit ?
Postby corrado » Fri Aug 29, 2014 8:53 am
I'd expect that the top bolt heads on the clamp will foul on some fatter dampers depending on the angle that the top damper mount is welded at.
corrado
Re: anti dive kit ?
Postby drivera » Fri Aug 29, 2014 9:58 am
just change the bolts supplied to mushroom headed allen screws , no clearance problem then :)
drivera
Re: anti dive kit ?
Postby Rich Oswald » Fri Aug 29, 2014 12:27 pm
drivera wrote:just change the bolts supplied to mushroom headed allen screws , no clearance problem then :)
I'll second that :D
Re: anti dive kit ?
Postby steve chapman » Fri Aug 29, 2014 6:25 pm
thanks for the information guys , ive seen somewhere they do a billet clamp , but havnt seen the link arm for it , any ideas ?
steve
steve chapman
Re: anti dive kit ?
Postby corrado » Tue Sep 02, 2014 10:53 pm
LTH kit has billet arm and bracket but they're not interchangeable with scootrs ones.
corrado
