Phbh float
Phbh float
Postby gp200ts1 » Thu Oct 11, 2018 6:26 pm
I have a few spare phbh floats, they are all 11 gram. What would happen if I fitted one instead of the 6 gram one?
gp200ts1
Re: Phbh float
Postby Angry Bloke » Thu Oct 11, 2018 10:10 pm
I used one in mine and it definitely ran boggy.
Also was difficult to start when warm !
Angry Bloke
Re: Phbh float
Postby Warkton Tornado No.1 » Fri Oct 12, 2018 12:14 pm
In all carburettors where there is a choice of floats, (not just the PH range that are really better suited to a four stroke but modified to suit two stroke ;) ) the float weight should be heavier to allow a higher fuel level to suit the characteristics of the two stroke.
Stick with what you have (if you must run the PH range) would be my advice :roll:
