jonno wrote:I had it dynoed,but with side panels off.Ive got MB panel filter and full panel fitted and it smoked badly even at half throttle,so way too rich.Now I think my mag seals have gone so cant plug chop.The panel and filter wouldnt have made too much difference would it?
jonno wrote:My TS1 is too thirsty 35 mpg,was thinking of buying a Rapido barrel and using the TS1s piston and head,and fitting an LTH inlet.Seems a straight swap?
jonno wrote:Running an open carb with a hole in the panel would replicate the dyno setup,and run better.But would it reduce the fuel usage,and not just increase the air to match the current jetting?
jonno wrote:Ive done a leak test and theres s leak somewhere but I cant find it anywhere.The is always fuel/oil under the sparkplug,outside the head, but it never shows any bubbles on the test.Have taken engine out for thourough check.Wasnt dynoed with panels on as couldnt be strapped down,although not a problem before.Time to go elswhere.So annoying.
