Miss fire???? Help.
Miss fire???? Help.
Postby Jimmyjames » Mon Sep 03, 2018 5:23 pm
Hi all am I missing something here??
3 stators ,
3 cdi,s ,
MB + A Tambs ingnition system.
Still feels like it's missing at high revs.
Any help would be great.
Cheers.
Jimmyjames
Re: Miss fire???? Help.
Postby MickYork » Mon Sep 03, 2018 5:39 pm
spark plug ?
Postby Jimmyjames » Mon Sep 03, 2018 6:30 pm
:D no plenty of plugs.
Jimmyjames
Postby MickYork » Mon Sep 03, 2018 7:10 pm
HT cable
Suppressor cap
Broken/loose magnets in flywheel
Postby Jimmyjames » Mon Sep 03, 2018 7:23 pm
All have been checked and changed, flywheel changed as Well.
Jimmyjames
Postby ROClarke » Mon Sep 03, 2018 7:59 pm
Went down the same blind alleys with mine,turned out to head gasket.
ROClarke
Postby daniel whiteley » Mon Sep 03, 2018 8:17 pm
I had it once on my old Yamaha 125 lc turned out it was big end on its way out so on hi revs it didn’t run right due
To movement
daniel whiteley
Postby Jimmyjames » Mon Sep 03, 2018 8:48 pm
Big end bearing.
This was a new build only done 1200 miles , first issue I had was the mag race was loose on the crank.
This has been the start of the problem.
Send a than all new bearings .
The only thing not changed was the crank. :(
Jimmyjames
Postby Jimmyjames » Mon Sep 03, 2018 8:58 pm
Yes , causing the flywheel to run out of true and osolate .
Hitting the pickup.
Dame !!!
Jimmyjames
Postby MickYork » Mon Sep 03, 2018 9:01 pm
Flywheel bearing also a possibility
Postby Jimmyjames » Mon Sep 03, 2018 9:07 pm
Changed twice :oops:
There is small movement up and down when the flywheel is on.
This is normal??
Jimmyjames
Postby ULC Soulagent » Mon Sep 03, 2018 9:43 pm
No, get your crank checked for trueness
Postby Jimmyjames » Mon Sep 03, 2018 9:47 pm
Dame, if it's the only explanation I'll send it back to bgm. :evil:
Jimmyjames
Postby Toddy » Mon Sep 03, 2018 11:03 pm
Have you bypassed the loom maybe a bad earth in there somewhere damp ignition/ kill switch ?
Postby Jimmyjames » Tue Sep 04, 2018 2:54 am
No not tried that , what's the beat way ?
Jimmyjames
Postby Toddy » Tue Sep 04, 2018 5:48 am
Jimmyjames wrote:No not tried that , what's the beat way ?
Just remove the green from the cdi which comes from the loom this will bypass your ignition
And loom
Postby Jimmyjames » Tue Sep 04, 2018 9:56 am
Thanks Toddy.
Jimmyjames
Postby Rich Oswald » Tue Sep 04, 2018 10:22 am
Carburation problem?
Postby Jimmyjames » Tue Sep 04, 2018 11:13 am
Definitely not the ingnition bypassed as Toddy said still the same . :cry:
Jimmyjames
Postby Norrie Bodge » Tue Sep 04, 2018 11:56 am
Is it Ducati CDI’s you’ve tried ?
As the cheap matsuyami ones are crap & break down under load
Norrie Bodge
Users browsing this forum: No registered users and 17 guests
