Denso iridium
Denso iridium
Postby Scooterdude » Fri Aug 03, 2018 6:58 pm
Anyone using them? Thoughts?
Scooterdude
Re: Denso iridium
Postby ULC Soulagent » Sat Aug 04, 2018 9:19 am
Overkill on a Scooter engine
Re: Denso iridium
Postby Scooterdude » Sat Aug 04, 2018 3:43 pm
ULC Soulagent wrote:Overkill on a Scooter engine
I sopose the same could be said about fancy 2 stroke oil at £12 + a litre.
Scooterdude
Re: Denso iridium
Postby daniel whiteley » Sun Aug 05, 2018 5:51 pm
I always used to find iridium plugs fouled up quickly on 2 strokes and went back to normal plugs
daniel whiteley
Re: Denso iridium
Postby Scooterdude » Mon Aug 06, 2018 8:27 am
daniel whiteley wrote:I always used to find iridium plugs fouled up quickly on 2 strokes and went back to normal plugs
I’ve just been having a play with one and was quite disappointed if I’m honest. Was supposed to be the same heat rating as the ngk 9 I’ve been using but despite this the cht temps shot through the roof, took it out put the ngk back in and all good.
The way i see it is the flame from these is so concentrated it makes so much more heat in one spot, something that we really dont want.
Scooterdude
Re: Denso iridium
Postby EddieStone » Mon Aug 06, 2018 9:57 pm
Waste of time for a two stroke Lambretta. Get the bog standard Denso, they last ages.
EddieStone
Re: Denso iridium
Postby ULC Soulagent » Tue Aug 07, 2018 10:55 am
My wallet would cry if I spent £12 on a Lt of fully synthetic :o
£3.60 a lt exol oil does me fine.
Re: Denso iridium
Postby Warkton Tornado No.1 » Tue Aug 07, 2018 12:15 pm
Exol fully synthetic specifically for an air cooled 'race' engine that is so good it is run @ 2%?
Obtainable for cash @ £15 for five litres?
What were they thinking?
Re: Denso iridium
Postby ULC Soulagent » Tue Aug 07, 2018 1:41 pm
What were they thinking?[/quote]
Ssshhh, it’s a trade secret :P :lol:
Re: Denso iridium
Postby GRTDKAD » Mon Sep 27, 2021 5:39 pm
Interesting to read this - and could have saved myself a few bob if I had earlier.
I was drawn in to the marketing of the DENSO Iridium and spotted them at a reasonable price at Camb Lamb so used one claiming to have similar heat characteristics as my Champion N3C.
First ride : Disappointed that the first 15 or so miles were really boggy and looking to stall repeatedly.
Ended up putting an N3C back in at the side of the road and it ran crisp again (TS1 230).
Only issue was I then ran out of fuel on the way home, getting just 45 miles rather than 60 miles out of a tank as I’d ridden harder in third gear to keep the revs up with the Iridium plug in. Relieved that I had a spare 2litre tank on the bike.
I assume if I wanted to persevere then I’d need to rejet the carb so can’t see much point.
GRTDKAD
Re: Denso iridium
Postby Warkton Tornado No.1 » Tue Sep 28, 2021 11:51 am
IMHO Denso Iridium fill a specific need for highly tuned engines & are probably no worse than NGK.
The likelihood of them being necessary on a road tuned Lambretta is extremely slim.
Meanwhile, the very under-rated Champion N3 battles on for a road tune :lol:
Admittedly, I seek out the Champion fine wire version that occasionally appear for bargain prices because I use no suppression with points ignition but have no proof that they are any better than the N3. The habit probably came about because running certain Dell'Orto's with an air filter tends toward flooding/hot start issues.... :roll:
