gp200ts1 wrote:Is it the front sprocket cushdrive slipping? This gives the same symptom as the clutch shipping at high revs.
corrado wrote:You can no longer get the Italian race plates, just the Indian road plates. Chiselspeed sell stronger springs. You can still get (last time I was in AFs) the Italian springs but not sure if they're any different in strength to the Indian ones.
bazza3004 wrote:I have tried two sets of the chiselspeed updated springs in two AF cassettes and both times the springs went coil bound before the clutch could separate correctly.the chisel spring seem to be made from thicker wire which I assume is causing this
corrado wrote:bazza3004 wrote:I have tried two sets of the chiselspeed updated springs in two AF cassettes and both times the springs went coil bound before the clutch could separate correctly.the chisel spring seem to be made from thicker wire which I assume is causing this
AF said you can overcome this by filing down the top of the xmas tree.
