missing lynx wrote:have a go as long as you have the tools to do the porting work and a plan B if it goes tits up
dickie wrote:.............For now, I'm wondering about the more fundamental issue of the bottom of the transfers being 1.5mm above the piston crown at bdc. Does this really matter?
coaster wrote:dickie wrote:.............For now, I'm wondering about the more fundamental issue of the bottom of the transfers being 1.5mm above the piston crown at bdc. Does this really matter?
Not ideal, would a 115 rod give you more options?
20180902_151359 (2) by richardhenderson1968, on Flickrdscscotty wrote:Scrap that mate!
dickie wrote:Today I managed to get an hour to myself so I had a fight with the motor I'm using as a basis (Indian GP125) and got the mag housing out (destroyed it) and the crank.
I reckon the crank is scrap as there is rust damage to the oil seal face. It's been cleaned up a bit with emery cloth, but there is still pitting that would need to be removed with a lathe realistically.
Am I being a fanny or should I just scrap this? Please base answers on the basis of the intent of this build which is a low spec, but well built 175; in other words, no more than maybe 15bhp (very optimistic) but very reliable.
When I see the photo it looks worse than it did in the garage.20180902_151359 (2) by richardhenderson1968, on Flickr
20180906_190411 by richardhenderson1968, on Flickr
FB_IMG_1536262242590 by richardhenderson1968, on Flickr
20180910_201126 by richardhenderson1968, on Flickr
20180910_201214 by richardhenderson1968, on Flickr
20180910_201141 by richardhenderson1968, on Flickr
20180910_202819 by richardhenderson1968, on Flickr
20180910_210647 by richardhenderson1968, on Flickr
20180910_211222 by richardhenderson1968, on Flickr
20180913_180923 by richardhenderson1968, on Flickr
20180913_184033 by richardhenderson1968, on Flickrshane BBoys wrote:So that’s a cast barrel? Using rudamentral kit did you say? Good show! I know how much I struggled on my Mugello and that Ali.
Shane
