Temperature sensor for AF Mammoth head
Postby Storkfoot » Fri Jul 13, 2018 9:10 pm
The AF Mammoth head has a M4.5mm threaded hole to, apparently, mate with either a SIP or Koso temperature sensor.
I have been searching, albeit on the small screen of my phone, for ages and I can’t find a sensor that’ll fit.
Can anyone point me in the right direction to a sensor of this size please?
By the way, I really don’t want to go with the plug attachment option.
Or, could it be that the standard CHT sensors are actually M4.5 where they screw into the plug attachment, in which case, all I’d need to do is discard the plug attachment??
Re: Temperature sensor for AF Mammoth head
Postby dickie » Fri Jul 13, 2018 9:41 pm
Postby Storkfoot » Fri Jul 13, 2018 10:31 pm
Thanks very much :)
I don’t suppose you could recommend a reasonably priced gauge that will mate to :P
A flat type I can stick on a toolbox rather than drill holes ;)
Postby dickie » Sat Jul 14, 2018 8:43 am
A cheap gauge is a tall order and stick on is even trickier.
This might do the trick, but it's a bit scant on technical details. I had a koso voltmeter on a bike once and that was decent quality.
http://www.campusskooters.com/koso-mini-3-cylinder-head-thermometer-honda-grom
Postby dickie » Sat Jul 14, 2018 8:49 am
This looks good, but I'd contact the seller about cable length and sender type.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F232392681097
Postby Storkfoot » Sat Jul 14, 2018 11:57 am
Thanks, Dickie. I have also emailed AF asking the question about the SIP CHT one which is £55.
Postby Fast n Furious » Sat Jul 14, 2018 12:53 pm
The stock SIP RTD sensor is 4.5mm. Just discard the useless plug adaptor.
Postby Storkfoot » Sat Jul 14, 2018 1:31 pm
Fast n Furious wrote:The stock SIP RTD sensor is 4.5mm. Just discard the useless plug adaptor.
Excellent. Thanks for the reply :)
