Fast n Furious wrote:I have commented on this sort of matter before.
A head that has a larger fin diameter than standard will require an oversized cowling.
This new cowling can no longer hug the cylinder like it used to.
Because there is now a cavernous gap between the cylinder and the cowling, most of the cooling air will follow this path of least resistance and exit without having performed any useful work.
These oversized heads are good at conducting heat from the combustion chamber but your cooling system is now pathetic at convecting the heat from the head and the cylinder away.
Not the best way forward in my opinion.
Rich Oswald wrote:Fast n Furious wrote:I have commented on this sort of matter before.
Do you think a re designed "stepped" cowling would work then?
Fast n Furious wrote:There is nothing wrong with standard sized heads providing they have sufficient density. (At least 900grams for a large block) Some Serveta heads were only 700g which can cause problems.
TBH. The main problem with lammy cooling is to do with the number of holes in and around the cowling where air can pass without it doing anything. The gap around the exhaust manifold and at the rear of the cylinder is where most of the air pisses out. Sort this out and all cooling problems disappear.
Users browsing this forum: Bing [Bot] and 56 guests
