Targa line alloy block kit.... And best 12v
Postby clyde » Wed Jul 04, 2018 7:13 pm
Are these any better than original. At the best part of £90 I'm wondering if it's just better to get the original parts chromed.
Also what's the go to 12v kit at the moment. Just getting a new scooter to restore and its a few years since I did one and know things move on.
clyde
Re: Targa line alloy block kit.... And best 12v
Postby Knowledge » Wed Jul 04, 2018 10:44 pm
Hmm. Probably worth editing your original post, and splitting your two questions into two threads, as these are very different questions.
Postby rossclark » Wed Jul 04, 2018 11:13 pm
And maybe in the Tuning and Kits section?
Postby Toddy » Thu Jul 05, 2018 6:09 am
Ill move it in there Clyde you may get more answers
Postby Scooterlam » Sun Jul 08, 2018 3:13 pm
I'm looking at the same control blocks.
I did find another company that did a similar block and the rod to £55.if I find the link ill post it.
In the end I found I had an MB block and it's a nice bit of kit.
It also has a bit built in for the rear brake cable.
If it's new and the tolerances are correct it will always be better than sloppy worn out stuff.
Scooterlam
Postby Dazts1 » Mon Jul 09, 2018 5:22 pm
JPP are the other brand. Used a set on the group 4 for 3 year without issue on the track.
Postby Rich Oswald » Tue Jul 10, 2018 3:04 pm
Dazts1 wrote:JPP are the other brand. Used a set on the group 4 for 3 year without issue on the track.
The JPP are great but buy a clutch adjustment wheel seperately, make life so much easier to adjust the cable.
