Is there such a thing made as anti dive for on-board discs
Re: Brakes
Posted: Tue May 29, 2018 1:35 pm
by rossclark
Never seen one.
In normal circumstances the braking causes the load to be transferred either to the link pin (drum hubs/links) or to the stud on the hub (disk hub / links) as this is in front of the axle the force tends to cause the dive. The anti-dive setup transfers the force to the fork leg via the link arm and is not connected to the links at all, under braking the fork link is free to move with the suspension.
In order to achieve the same effect you'd have to find a way to make the backplate free to rotate around the axel (drum backplate in disk links, maybe?) and then find a way to connect it firmly to the fork leg.
Re: Brakes
Posted: Tue May 29, 2018 6:26 pm
by Scooterlam
Got ya.
So if I was to rotate the back plate 180 degrees. It's hydrolic so no linkage issues. Then use the bolt that is normally attached to the link as the fixing for the anti divelink.
Re: Brakes
Posted: Tue May 29, 2018 10:42 pm
by rossclark
Interesting concept.
You'd have to find a way to ensure that the link from the stud was free to move around it when it needed to and to mimic the geometry involved in the normal set up - I believe it's important for the correct action that the forks, fork links and pivot points form a parallelogram.
I'm sure someone with more engineering experience will be along to tell us why that won't work shortly
