Gear box oil
Gear box oil
Postby Stesjh » Thu May 24, 2018 9:41 pm
Out of interest what gear box oil are people using in tuned engines, need to change mine. Currently running a 30bhp TS1.
Stesjh
Re: Gear box oil
Postby nsaints » Thu May 24, 2018 10:28 pm
I use the stuff MB sells. Maxima I think it’s called without looking it up. It’s not the cheapest, but you can find it around £10a liter delivered on eBay.
I appreciate asking for an opinion on best oil is inviting 20different answers, but I really rate this stuff.
nsaints
Re: Gear box oil
Postby Hammer RB230 » Sun May 27, 2018 10:47 am
I use Maxima in both my 30HP RB230 and my RT195, had no issues in either clutch behaves as normal. I found it the cheapest from a motocross site apologies cannot remember the name.
Good quality oil would reccomend.
Hammer RB230
Re: Gear box oil
Postby MickYork » Sun May 27, 2018 3:41 pm
I use the Maxima 85 and can't fault it.....saying that i couldn't fault the cheaper stuff either :?
I think with the different/modern clutch compounds a more "modern" oil may be of benefit.
Think i got my last lot from Oiltech.
Re: Gear box oil
Postby Knowledge » Mon May 28, 2018 9:20 am
I am running a straight 40 mineral oil from Morris, on the recommendation of Harry Barlow.
No clutch slip yet on a 6 plate clutch of my own design, but then the engine is some way from full power at the moment.
Re: Gear box oil
Postby coaster » Mon May 28, 2018 10:13 am
Knowledge wrote:I am running a straight 40 mineral oil from Morris, on the recommendation of Harry Barlow.
Is that SAE 40 Martin? just asking in case I need to buy something on the Spanish trip
Re: Gear box oil
Postby Knowledge » Mon May 28, 2018 10:45 pm
Yes Colin, SAE40. Morris classic oil “golden film oil”
Re: Gear box oil
Postby Fast n Furious » Tue May 29, 2018 2:08 am
I used to use a 75 weight oil in the winter and for some track use.
For touring, I suggest sticking with the recommended 90 weight (ST90)oils which work well when the casings have really warmed up.
Lighter oils don't offer the same protection under such prolonged loads.
Don't use EP oils as this will have an adverse affect on the clutch.
