Chiselspeed CST3
Chiselspeed CST3
Postby Simon ELC » Sat Apr 28, 2018 1:37 pm
Anyone using the Chiselspeed CST3 touring pipe?
I was wondering how low down it makes usable power and what gearing it would pull.
Simon ELC
Re: Chiselspeed CST3
Postby bike grim » Sat Apr 28, 2018 1:44 pm
depends on cc and on your port timings. Trying 4.45 gearing at the moment in a DSC Scotty lined TS1 with a 30mm PHBH and and feels good.
Postby Simon ELC » Sat Apr 28, 2018 1:59 pm
Thanks Grim.
Toying with putting one on my TS1 253. My timings are around 125 trans 185 exhaust. I'd like to get down to around 4.5 final drive.
Simon ELC
Postby Scooterdude » Sat Apr 28, 2018 3:07 pm
Im using an NK road pipe which is very similar to the cts3 love it. I do wonder as both are made in the UK they are one and the same and made by the same company?
Scooterdude
Postby corrado » Sat Apr 28, 2018 3:11 pm
Scooterdude wrote:Im using an NK road pipe which is very similar to the cts3 love it. I do wonder as both are made in the UK they are one and the same and made by the same company?
Different pipes from different manufacturers. Going back 2 or 3 years they were both made by NK but stiff different pipes. CST3 produces power lower down. The AF pipe is normally referred to as "mid-range", produces power higher than a CST3 but lower than a race pipe.
corrado
Postby Simon ELC » Sat Apr 28, 2018 5:18 pm
The NK road pipes are great. I do have one. Its been welded up a few times. I find they sit too low, I was forever grounding mine on the bends.
Simon ELC
Postby Tractorman » Sat Apr 28, 2018 9:01 pm
I put a CST3 on mugello 225 and 28mm dellorto and after re-dyno carb adjustment I could not believe the difference just changing from an Ancilloti could make, this is with the sidecar.
Postby bike grim » Sun Apr 29, 2018 12:43 pm
Tractorman wrote:I put a CST3 on mugello 225 and 28mm dellorto and after re-dyno carb adjustment I could not believe the difference just changing from an Ancilloti could make, this is with the sidecar.
I’d like to know your jetting if poss. Did you go up massively on main jet?
Postby Tractorman » Sun Apr 29, 2018 4:28 pm
Main jet went from 104 to 110. pilot 49 slide 40 needle X7P2.5
Postby bike grim » Sun Apr 29, 2018 5:16 pm
Thanks.
Postby kev johnson » Tue May 08, 2018 11:52 am
Had my Scooter on the Dyno at Chiselspeed on Friday - Avanti 230cc with Super tourer & 30mm Dellorto
Martin suggested I try the CST3, so we swapped the pipes on the Scooter and i took it out for a spin
Fantastic, loved it, massive improvement, so out came the credit card and I bought one on the spot :lol:
Kev
kev johnson
Postby Rich Oswald » Tue May 08, 2018 12:48 pm
kev johnson wrote:Had my Scooter on the Dyno at Chiselspeed on Friday - Avanti 230cc with Super tourer & 30mm Dellorto
Kev
He's a good salesman is Martin :lol: :lol: :lol:
Postby kev johnson » Tue May 08, 2018 1:42 pm
Kev
He knew exactly what he was doing Rich :lol: :lol:
kev johnson
Postby Storkfoot » Sat Oct 06, 2018 10:42 am
I have made the decision already to buy one for my TS1 to replace the Supertourer that is on there. Just before I do though, has anyone any feedback on how sturdy they are please?
Postby bike grim » Sat Oct 06, 2018 12:15 pm
Sturdy enough. But do sit a bit low so watch it on speed bumps
Postby johnnyjarvis » Sat Oct 06, 2018 12:47 pm
Replaced my Taffspeed mk4 with a CST3.
Loved the taffy pipe, forced to get a new pipe due to rusted through u-pipe.
I would say the cst comes in as early as the taffspeed and does everything the taffy did , possibly better.
Hangs a little low from the barrel but use common sense when navigating speed bumps and all cool.
Really pleased with it.
johnnyjarvis
Postby Storkfoot » Mon Oct 08, 2018 9:55 pm
Thanks for the replies. I just wanted to sound out prospective issues before buying.
Postby Storkfoot » Sat Oct 13, 2018 7:58 pm
Is anyone running one with an AF Mammoth head? Just wondering if there are any clearance issues.
Postby matthew » Mon Oct 15, 2018 12:11 pm
I've got a CST3 with a Mammoth Head, and have no fitting issues.
matthew
Postby Storkfoot » Mon Oct 15, 2018 1:07 pm
matthew wrote:I've got a CST3 with a Mammoth Head, and have no fitting issues.
Thanks.
