Birth of a kit
Re: Birth of a kit
Postby Warkton Tornado No.1 » Tue Nov 22, 2016 2:34 pm
Post by Scooterlam » Mon Nov 21, 2016 12:10 am
So is this kit related to the one recently run up on JBs Dyno.
Sorry if this post is ON Topic.
Birth of a kit
Postby Sticky » Sun Oct 30, 2016 4:56 pm
How 3D printing technology is changing Lambretta tuning part development...
http://www.scooterlab.uk/birth-of-a-cyl ... 0-feature/
Sticky
Top
Re: Birth of a kit
Postby Dimitrios_231 » Sun Oct 30, 2016 5:33 pm
What a kit,I want one,
it is so great not having these studs in between...
Well done SLUK ;)
Dimitrios_231
Top
Re: Birth of a kit
Postby Digger » Sun Oct 30, 2016 6:24 pm
So what happened to the 305?
Digger
Top
Re: Birth of a kit
Postby Sticky » Sun Oct 30, 2016 6:37 pm
The 305 will only ever exist in small numbers due to BSG being so busy with other projects, but there was obviously a demand so this project has been developed as a cheaper option. For me, the more interesting proposition is the SST touring option.
I think there's a lot more people who think they want 50hp than can actually handle it. However, a little less power, decent fuel consumption, low vibration and power from really low down are what I'd look for in an engine that I'd actually use.
John & Mikey have 'run up' various kits on their dyno, but my 'ON topic' guess is that you are referring to the 305 as previously asked by Digger.
I do hope that helps & we have no reason for:
Re: Birth of a kit
Postby Scooterlam » Tue Nov 22, 2016 8:21 pm
Was that the one Andy Gillard posted up on FB in a scooter I believe is called "Blue is the colour" "Glad all over^ would be a better name.
Scooterlam
Re: Birth of a kit
Postby Sticky » Thu Dec 15, 2016 7:22 pm
Warkton Tornado No.1 wrote:The basic design of the rear hub supported on the lay-shaft is the cantilever principle as used on V*spa front & rear hubs as well as virtually all cars.
I have no doubt that adding a supplementary support would help but whilst there are other problems that have been indicated by some really well informed responses given recently; I think adding a supplementary support is only masking the problems.
The reaction given by Nudger is not based on my gut reaction, or anybody else’s, for that matter. He has enabled a logical, methodical approach using known techniques that enable us to make sound judgements.
For now, to achieve ultimate ‘peace of mind’ the best, most practical solution may be a non destructive test of any lay-shaft likely to be used, including any ‘super-duper-bling-looking-yet-not-certified’ replacement lay-shafts that some would have us queuing up to buy!
Couldn't be arsed in a long forum answer to all your digs, so I wrote a long article instead.
http://www.scooterlab.uk/fixing-weak-links-opinion/
Sticky
Re: Birth of a kit
Postby Adam_Winstone » Thu Dec 15, 2016 8:31 pm
A thought provoking read.
Re: Birth of a kit
Postby ToBoldlyGo » Thu Dec 15, 2016 10:28 pm
It is indeed. Luckily for me, I suppose, I'm not exactly a racer. But it does make you think. It's a fine line between keeping it original and using fancy new parts and sort of blurs the idea of classic scootering.
Re: Birth of a kit
Postby Warkton Tornado No.1 » Fri Dec 16, 2016 12:25 am
Re: Birth of a kit
Post by Sticky » Thu Dec 15, 2016 7:22 pm
I’ve been designing components for the best part of forty years in various industries.
The ‘safety critical’ sectors where certification is carried out have included Defence, Motor Sport, Automotive & the Lift Industry.
Inspection of components to ensure they conform to the Designer’s remit is something that has to be carried out, regardless of whether that industry is self regulating or not.
I would have read your article in any case, despite your provocation.
In it, you mention the failure of lay-shafts experienced by Innocenti. You don’t state how they worked to resolve the problem, but almost certainly they did & their efforts would have undoubtedly been recorded & the engineering drawings modified accordingly.
Thus, everything associated with the manufacture of OEM lay-shafts will have come about as a logical process of evolution.
Of the ‘many’ failures you mention again in your article, you have no absolute evidence as to why they have failed. You talk about ‘the thread’ but that will not have been the reason for failure. Perhaps you elude to the undercut, but there is a common misconception that they weaken components, whereas applied correctly, they effectively strengthen parts by relieving stress.
Thankfully, other Forum members are being constructive & there has been some analysis of the broken lay-shafts that have been made available.
Yet, before any evidence for the reasons of failure can be presented, you publish details of a new alternative to OEM lay-shafts. As is your right to do so.
The fact that you consider it to be superior can be in no doubt.
My own opinion (if I’m allowed one..) is that it ought to be superior.
Yet, how does either of us know?
Do you know details of the material? Do you know how many stages are involved in the forging of it? Do you know by what means the spline & thread has been produced? What thread undercut has been utilised? What heat treatments are used throughout the manufacture? What inspection methods have been utilised? How many stages are involved in Inspection?
I don’t care that my opinion may not be popular with you, or anybody else for that matter.
Just because I am prepared to say, effectively:
“The new, special lay-shaft looks purposeful but how can we be certain it is any better than the OEM components it aims to succeed?”
meets with your disapproval & consequently your attempts to vilify me for stating my opinion on a Member’s Forum.
Re: Birth of a kit
Postby Sticky » Fri Dec 16, 2016 9:32 am
I'm not attempting to vilify you, but you were accusing me of trying to push people towards buying untested new products that they don't need. (can't be arsed to look for quotes)
I strongly object to that portrayal.
And the quote about forum 'experts' was not directed at you specifically. There are a lot of 'experts' on various forums who give out bad advice or narrow-vision opinions.
I'd rather be honest and say I don't know something for sure than try to suggest that a problem does not exist because I haven't seen it in all my years man and boy etc etc.
Sticky
Re: Birth of a kit
Postby Scooterlam » Fri Dec 16, 2016 10:18 am
What if any cetification would be availabe to the manufacturer.
How feasible is it for a small producer to achive the creditation that would satisfy some of us.
Scooterlam
Re: Birth of a kit
Postby Sticky » Fri Dec 16, 2016 10:55 am
Scooterlam wrote:What if any cetification would be availabe to the manufacturer.
As the article alludes to, certification is very expensive in most cases, and would render most of these small batch products uneconomically viable.
It only works, like in the case of SIP rims, to test the market demand and profitability and then to go for certification if there is a demand.
Certification only works if it is enforced and you can tell the crap products because they are the only ones without a certificate. With the current situation there's no guarantee that a certificated product is better than a non-certificated 'race use only', an I know examples of the reverse.
With enforcement none of these new products would likely exist and for me that's a worse scenario than what we have.
Sticky
Re: Birth of a kit
Postby Warkton Tornado No.1 » Fri Dec 16, 2016 12:28 pm
Re: Birth of a kit
Post by Sticky » Fri Dec 16, 2016 9:32 am
Sticky. You are an educated journalist.
I have accused you of nothing.
I have stated my misgivings about the reasoning behind the failure of lay-shafts.
I have sought to defend a product that cannot be proven to be flawed in its design, despite the issues of failures, because there are other factors involved.
I have attempted to be pro-active in establishing the truth behind failures of OEM lay-shafts.
As you ‘couldn’t be arsed’ to look for quotes, yet object to your perceived accusation/portrayal of you, I can only guess that you take exception to my response repeated here.
I can only suggest you read through that again & satisfy yourself as to which one of us was the most ‘factual’ unless, that is you have the OEM remit to verify your perception that “the layshafts are now being stressed way beyond any design specifications”
Post by Sticky » Wed Nov 02, 2016 10:49 pm
The design is not necessarily flawed, and agree that over or under-tightening can be a factor.
However, two things are certain:
1. at least one death can be attributed to a broken layshaft, and several crashes I know of (DSC Scotty among others)
2. the layshafts are now being stressed way beyond any design specifications both by the power of modern motors and pie and pint consumption of modern scooterists
If the reason that anybody died due to a layshaft failure, then surely there must have been a full analysis as to why.
Whether the failure was due to inherent bad design, metal fatigue or any other reason, thorough tests would show the reason.
If I was in the remotest way connected with a person that died in such circumstances, I would want to know why.
Sticky, I don’t doubt what you say about the failure of a layshaft.
However, I doubt the reasons you suggest might be the total cause of the failure.
Before you cast such doubts upon the integrity of the design, & I’m sorry to repeat the phrase, you really ought to quantify, & qualify, the total facts.
I really am surprised @ the assumptions you’ve made & it’s not for the first time you’ve mentioned the fatality, tragic as it is.
That gives neither you, or I, the right to dismiss what can be proven to be an inherently sound component (having served well in tens of thousands of instances) just because it may be the case that another 'sexed-up' design awaits in the wings....
Re: Birth of a kit
Postby Sticky » Fri Dec 16, 2016 12:40 pm
I strongly object to this because it suggests that I'm mentioning a death and scaremongering "just because it may be the case that another 'sexed-up' design awaits in the wings...."
Frankly, that's a load of bollocks, which is why I wrote the article. End of
Sticky
Re: Birth of a kit
Postby Warkton Tornado No.1 » Fri Dec 16, 2016 1:05 pm
Post by Sticky » Fri Dec 16, 2016 12:40 pm
Your interpretation of what is said is wrong.
You really should try sticking to facts, not your assumptions.
I take exception to your sweeping assertions.
I suggest you try & quantify "the layshafts are now being stressed way beyond any design specifications" because that may not be so emotive & a worthwhile action to back up your statement of fact.
Just because you probably can't do that, don't have a go @ me because of your discomfort.
You simply don't know what safety factor was engineered into OEM lay-shafts!
I hope that is "End of" but suggest you (we) take this away from the public Forum if you have anymore to say. You have my contact information.
Re: Birth of a kit
Postby drunkmunkey6969 » Fri Dec 16, 2016 4:42 pm
Adam_Winstone wrote:A thought provoking read.
In more ways than one...
drunkmunkey6969
Re: Birth of a kit
Postby Knowledge » Fri Dec 16, 2016 6:19 pm
Anyway, what about the birth of a kit?
Any updates that can bring this thread back on message and away from layshaft failure CSI?
Re: Birth of a kit
Postby MickYork » Fri Dec 16, 2016 6:37 pm
Are the layshaft threads cut or knurled ?
Re: Birth of a kit
Postby rumiman » Sat Dec 17, 2016 8:02 am
Layshafts here layshafts there layshafts every fucxxng where Na Na Na Na Na Na Na. Na Na!
Any news on the kit ?
rumiman
