HxPaul wrote:I had a 1948 Harley-Davidson panhead and I was riding it one day when it locked up and threw me off.When I stripped it down I found that one of the teeth on the second gear had sheared and locked the gearbox.I was told by an engineer that it was because it was so old that the gear had become hard/brittle through use and that had caused it to break.I'm no metalurgist so I took this as being correct.The bike at that time was 30+ years old,we are riding around on vehicles that 50 years old,some are even older,so if the engineer was right about age and metal getting harder through use and age,its no wonder that some of the original layshafts break through the constant torquing and unfastening of the rear hub.
dickie wrote:I agree with Warkton. The failures in the pictures posted by strummer and nudger are in a section which is not subjected to drive torque. Drive torque is transmitted via the splines, not the nut.
My conjecture is that the shaft has failed due to fatigue induced by the ability of the hub to rock slightly on the shaft and therefore 'bending' the nut up/down and forward/aft on the shaft.
I'd really like to get a look at a variety of close up shots of the failed shafts to try to determine the failure mode.
Strummer10 wrote:
Just going to 'float this one', but is it conceivable that a new rear wheel bearing could be a potential cause, IF it was perhaps not locking tight against the aluminum engine case housing from install.........thus moves within the aluminium engine casing as the layshaft turns ?
That would induce a bending moment at the other end of the shaft in the gearbox end plate with the outcome being either end plate failure or the other end of the layshaft failing, so no, I don't think that's a factor.
Don't take that as a put-down by the way. I'm a big fan of thinking out loud. And often talk utter bollocks to stimulate thought at work.
Post by dickie » Sat Nov 05, 2016 11:13 am
Innocenti's advice that a small amount of play in the hub is acceptable indicates to me that the hub/shaft design isn't exactly great. And I suspect is a significant contributing factor.
Post by dickie » Sat Nov 05, 2016 1:19 pm
OK Warkton. I see what you mean. I think you're interpretation is correct, not mine.
But I think we need to separate the issues. One being security of the hub against the cone and the other being the bending moment in the threaded section. I'm cautious about being blinkered in my view here as I've only seen 2 pictures of failures. But from what I've seen, they have failed due to fatigue (repeated bending) or sheared (torque). Again, like Warkton I'm very sceptical about the latter as there should be diddly-squat torque going through that portion of the layshaft.
Post by ToBoldlyGo » Sat Nov 05, 2016 3:04 pm
We must assume that SIL layshafts, at least, benefit directly from Innocenti development.
holty wrote:i have read quite a few posts on layshaft failure recently, with lots of theorys and explainations, all may be possible, surely the question is how to prevent layshaft failure, when you look at the engine case from above it points in the same direction as the frame, the layshaft at 90 degrees the the engine, then the wheel paralell to the engine, this is like three sides of a square, if you were to add a forth side this would make it much more stable and put much less stress onto the layshaft in the first place, i m talking about an arm with a bearing in it that fastens to the rear drum, probably using the 3 threaded hub pulling holes, that then fastens to the engine, maybe around the engine mounting(gp type) i have seen this type of arm used on high powered autos to stop them snapping the engine case in half, with the search for more and more hp this is becoming a more serious problem.
holty
