Variatronic "Wassell" conversion
Re: Variatronic "Wassell" conversion
Postby Thackers » Tue May 20, 2025 7:44 pm
Hi I'm also thinking along the lines of giving this a go. Just a couple of questions if i may
Do you have to have a battery in this conversion? The question is asked in the topic but doesn't get answered. I don't wish to use a battery.
How would you connect a sat nav? I'm using a mod charger for this from the dc output on the standard regulator
Are there any updates on this project? It's been a while since the original and i was wondering how the modified units have been performing?
I'm no electrician so any help simplified would be fantastic :lol:
Thackers
Postby Wack » Fri May 23, 2025 10:44 pm
There's a far easier way to do the wiring now so no need to remove the resin Dave.I've done a few for mates but all using batteries either fitted in a tray in the standard toolbox or under the spare cut out on long range tanks.You don't need a big battery something small like 4 amp does the job especially if using LED bulbs.Whether a capacitor could be used I'm not sure although I've used them to stop SIP speedos resetting on AC systems. As for reliability,I've not had any problems with the ones done and it's just a case of using the MB switch that has a live output on the 1st click(ignition) to connect ancillaries.
Postby gp200ts1 » Sat May 24, 2025 9:05 am
Wack wrote:There's a far easier way to do the wiring now so no need to remove the resin Dave.I've done a few for mates but all using batteries either fitted in a tray in the standard toolbox or under the spare cut out on long range tanks.You don't need a big battery something small like 4 amp does the job especially if using LED bulbs.Whether a capacitor could be used I'm not sure although I've used them to stop SIP speedos resetting on AC systems. As for reliability,I've not had any problems with the ones done and it's just a case of using the MB switch that has a live output on the 1st click(ignition) to connect ancillaries.
What’s the alternative method without removing the resin?
Paul
gp200ts1
Postby Thackers » Sat Jan 10, 2026 6:09 am
Hi, I've still not round to this :roll: but intend to hopefully before the season starts.
I've got one of the Cam Lam fuel gauge's now and as before sometimes run a sat nav so i think i have to go with fitting a battery. The only space i can do so is above the rear mudguard and fit a holder to the frame around the point where the old coil was fitted. This is a small space and the only battery option i can find are a long, thin and low type with either 1.2 amps on the smallest size (easier to fit in ) or 2.3 amps being a little bigger. Would either of those amps be enough? Like i say it's only to run the fuel gauge and occasional sat nav with a view for perhaps a temp gauge if i feel like more brain aggro :lol: :lol: :lol: I'm no electrician :roll: :roll:
Lloyd, i would be very keen to know the trick of not removing the resin, i seem to have acquired a shaky hand now :( so not having to get close to the thin L.T wires could mean make or break :D :D :D
Thackers
