175 iron kits...
Re: 175 iron kits...
Postby Andie » Mon Nov 14, 2016 10:47 pm
Thanks WT1, I must admit i'm not a thrasher through the gears. tbh the Gori kit is literally sold as 'not a fire breather' - i wanted a 175 with relevent piston so as to have a thicker barrel and be (maybe) more reliable.
Thanks Phil D, yes yours seems exactly like mine. it should be off the clock on my 80kph speedo...
Now that I know that it's a bit slow I will recheck everything I can then see about getting it to a mechanic again. it had a bit of a kick in since the dyno from burglars a few weeks ago (it was kicked over and got a bit dented) but I checked the exhaust nuts (just in case) and re-oiled Etc.
Best A
Andie
Postby Andie » Tue Nov 15, 2016 9:49 pm
so, I went to strip down the carb and found the throttle cable had frayed so much at the carb end that bits of wire in the cable outer were inhibiting the movement of the slide. I feel a bit sheepish tbh but glad its sorted. It ran off the clock today on the dual carriageway and grunts very satisfactory, as it did when dynoed. I must have run it like this for a few weeks. Lesson learnt
Thanks for your help, as I just wasn't sure what was going on, and good to know what I should expect. As it goes I'm happy!
Andie
Postby Warkton Tornado No.1 » Wed Nov 16, 2016 12:22 am
Postby Warkton Tornado No.1 » Mon Nov 14, 2016 9:53 pm
Your right hand glove is not Teflon lined on the palm & fingers is it? :)
Thanks for the confession Andie.
I wasn't too far off, was I?
i think most people on here appreciate feedback & that makes us want to help. Nothing to do with 'ego' :roll:
Postby Andie » Wed Nov 16, 2016 1:05 am
Thanks WT1. And everyone else who scratched their head. i do feel a bit daft. daft but speedy :)
Andie
Postby Adam_Winstone » Wed Nov 16, 2016 10:12 am
Glad to hear that you've identified the issue and got it sorted.
Happy and safe scootering :)
