For what its worth and this is from memory,
Avanti Pistons abcd increments are 0.01mm. if this is industry standard I don't Know.
phil99 wrote:
Ride scoot as it is now for about 200 miles to let it colour up, Then remove barrel and check piston for blow by,
if it is clean then the piston rock was probably caused by the piston hitting the head due to the carbon build up which was in excess of 2 mm.
Phil
bore clearance 0.07 mm to 0.013 mm
Warkton Tornado No.1 wrote:Hi Phil.bore clearance 0.07 mm to 0.013 mm
Do you really mean:
0.07 to 0.13 mm
which is 0.0028" to 0.0051"
rather than 0.0028" to 0.00051"?
Just over half a thousandth of an inch is surely a typo.
Sorry to appear pedantic.
