Jeff t wrote:No SIP tubeless, tried the tyre last night and not much difference. Where I am at now is, I’ve changed the springs, secured top buffer, removed some weld splatter on the inside of the forks as one of the links was a bit tight.
Everything looks spot on now apart from two issues, tyre seems to run out by about 5mm although disk is spot on and the wheel is slightly off centre which you can’t adjust.
I’ll put back together and try it
What type are the softer engine mounts and where do you get them from ?
Jeff t wrote:Well just been out and it’s miles better, I changed the springs but I think what made the difference was the engine was touching the frame. I have a Casa engine bolt where you can lower the engine and the air intake was touching the frame so lowered it off a bit. Thanks to all those who offered help get some miles on now and see how it goes.
