pinprick airleak in barrel wall
Re: pinprick airleak in barrel wall
Postby Bilko » Thu Feb 06, 2020 9:58 pm
It's showed no signs of letting up after several thousand miles.
Bilko
Postby Andy B.L.C. » Fri Feb 07, 2020 12:19 am
Would that be missing a 'no' somewhere B, or not, distinction important? Sounds like what I'm needing to sort out my Poland rally oil leak! It wasn't a leaking BGM side casing casket but a post end plate fixing welding job pin prick leak...
Andy B.L.C.
Postby Psychedelicropcircle » Sun Feb 09, 2020 1:45 pm
Used some JB kwik weld drilled a wee hole to let it grip a bit better. Leak test it after graft tomorrow! :cry:
Postby coaster » Mon Feb 10, 2020 6:07 pm
+1 for JB weld but do make sure its fully cured before starting the engine. I got a little over enthusiastic cutting a finger port in a SR225 barrel once, slapped some JB Weld on it, popped the barrel on then thought it would be a good idea to take it for a quick spin.....didn't even make to the end of the drive :oops: 2nd attempt worked as I left it to cure for 24 hours 8-)
Postby Psychedelicropcircle » Tue Feb 11, 2020 5:29 pm
Sorted ;)
Gearbox next
Postby Toddy » Tue Feb 11, 2020 10:55 pm
Psychedelicropcircle wrote:Sorted ;)
Gearbox next
Happy days , 5 speed ?
Postby Psychedelicropcircle » Wed Feb 12, 2020 11:29 am
Gearbox next
Aye the budget AF one!
Postby Toddy » Wed Feb 12, 2020 11:34 am
Gearbox next
Just fitted af one in my 240 not ridden yet though
