GT240 Piston
Re: GT240 Piston
Postby Leotech » Fri May 10, 2019 1:40 pm
GeorgeS wrote:You can contact Eden Bakewell on Facebook directly or via the Spliffspeed page, he can supply a piston with the modifications already, but I think he's on holiday at the moment.
Spoke with Eden, he's been very helpful, Not got the thing back up and running yet but a piston is available.
Leotech
Re: GT240 Piston
Postby Bilko » Fri May 10, 2019 6:12 pm
ULC Soulagent wrote:I use an broomshaft cut too fit under my bench seat and cut notches into it for every lts of fuel I put in when on new long range tank. Now it’s a case of a quick dip with the stick and working out how many lts and oil I need :D
Great idea. I'm always trying to work out how petrol I've got in the tank.
Bilko
Re: GT240 Piston
Postby Warkton Tornado No.1 » Fri May 10, 2019 6:36 pm
Getting back to the subject, there was a time when I was contemplating building a GT240 for somebody, but that idea got shelved.
Nonetheless, the piston was a consideration, though I still don't understand why the TS250 piston was selected rather than the DT250, which is only 1mm different in compression height & already has inlet ports to suit.
Despite asking the relevant people, no answer was ever forthcoming.
Anyway, I now have a DT 250 (70 mm) piston to build into a TS1 kit & apart from ring peg positions need checking, believe that it will work very well.
I would say definitely worth considering as a reasonable priced spare, almost ready to fit apart from the cylinder base difference, but ensure that the later type is bought, unless you like Dykes rings.
They can be had for less than 30 quid, too..... ;)
Re: GT240 Piston
Postby corrado » Fri May 10, 2019 7:26 pm
Would 1979 be considered a "later" type?
https://www.ebay.co.uk/itm/Piston-Kit-S ... Sweq5apyOR
corrado
Re: GT240 Piston
Postby rossclark » Fri May 10, 2019 8:48 pm
That looks like dykes ring in the pictures
Re: GT240 Piston
Postby Warkton Tornado No.1 » Fri May 10, 2019 10:41 pm
corrado wrote:Would 1979 be considered a "later" type?
As rossclark says, that is Dykes ring type.
I have seen them @ £25.20 on ebay, but got one from Grampian/Mitaka in the end.
