Solid Air wrote:If I remember correctly, RaveyDavey is running Li150 gearbox with 47/18 giving an FDR of 4.44
Watfordwhite wrote:Went like hell.
Dave, are you using a 4% mix?
Raveydavey wrote:Solid Air wrote:If I remember correctly, RaveyDavey is running Li150 gearbox with 47/18 giving an FDR of 4.44
Sorry for the late response. I can confirm the above. 47 tooth AF cassette clutch with an 18 tooth sprocket on a LI150 box. The jump between 3 and 4 is pretty big so If im riding with others I spend a lot of time in 3rd. A 5 speed box wouldn’t be a bad idea. Although if you’re riding solo, as I tend to most of the time, give it the beans, get it above 5.5k revs in 4th and it’ll stay up there quite comfortably. Plus it will accelerate rapidly from high 50s to high 70s. Starts to get scary at 80![]()
I’m now running Maxima K2 at 3%.
coaster wrote:
That is really quite astonishing, most 225 or bigger won't pull 4.4 gearing. What is so special about the porting? he must be tapping into something new, make you wonder what he could do with a big block
Raveydavey wrote:Despite rumours there is nothing official about him doing a big block kit, which is a damn shame because I would be the first in the queue to get one if he did.
Raveydavey wrote:In case anyone is still interested, I’m now 4000 miles in on my Chiselspeed built Quattrini and I’m still loving it. Ive added an EGT so I can see what’s happening when I hoon it, which is most of the time. It’s still happy as Larry riding all day at 60-65, but now I can see when it’s getting hot I can sit at 70-75 and it doesn’t miss s beat. Technique is to keep rolling the throttle. My main jet is rich so whenever the temperature is looking too hot I blip the throttle Wide open a couple of times and it drops straight away. Fuel consumption is still very good. There may be some downsides but I haven’t found them yet.
