lambretta 290 rotax
Re: lambretta 290 rotax
Postby Knowledge » Sat Oct 21, 2017 9:46 pm
Well done at getting this far Holly.
Just a thought. Will the panels fit with the tank in the new, forward position?
Postby holty » Mon Oct 23, 2017 9:38 am
Knowledge wrote:Well done at getting this far Holly.
Yes I’ve had both panels on and they fitted fine.
holty
Postby holty » Tue Oct 24, 2017 9:53 pm
new engine mountings from afr the upgraded type
ImageUntitled by stephen holt, on Flickr
mounts fitted in engine
ive also got 2 fuel cap flaps
and engine is in place
holty
Postby holty » Tue Oct 24, 2017 9:59 pm
you may notice that i have taken off the legshields, i was going to do a repair to them but have decided to use a fiberglass pair that i have thats got a built in toolbox and im going to put the radiator in the toolbox and cut some holes in the front, will add some pics when i have made some more progress.
holty
Postby Knowledge » Tue Oct 24, 2017 11:31 pm
When I built my LC 225 back in the day, I used GRP legshields with a Yamaha 350 radiator mounted behind, and low. All the fresh air was ducted through the front mudguard and into the rad, that sat in a special legshield toolbox. There was a baffle built into the toolbox so that air HAD to pass through the radiator, and then there were holes in the floor that allowed the hot air to pass discretely from the tool box.
The result of all this was that I had no visible holes for the air. None on the front of the scooter, and none on the back of the tool box.
I still have the mould for the radiator cover if this tickles your fancy.
Postby holty » Thu Oct 26, 2017 8:40 am
thats a very kind offer, many thanks, but ive done a lot of work on these and i will be using them, heres a pic
holty
Postby holty » Wed Nov 01, 2017 10:53 pm
ive made a bracket for the battery tray and ive converted my bgm stator from ac to dc and fitted it to my engine and flywheel fitted, external pick up fitted and connected my coil, and ive got a spark, happy days.
holty
Postby holty » Sat Nov 11, 2017 6:36 pm
i have started to paint the legshields on the inside, while i was at it ive also painted the left runner board as it had a few rust issues, the front mudguard has the same problem so i am sorting that out as well, its slowly turning into a restoration, i was supposed to be just fitting an engine, heres a couple of pics
holty
Postby Digger » Sun Nov 12, 2017 1:34 pm
Getting there.. :D 8-) 8-) 8-)
Digger
Postby a-teamlambretta » Sun Nov 12, 2017 5:53 pm
Stop fecking about and get it fired up, suspense is killing us...
a-teamlambretta
Postby holty » Mon Nov 13, 2017 4:37 pm
a-teamlambretta wrote:Stop fecking about and get it fired up, suspense is killing us...
ha ha, i feel just the same, im still waiting on my water pump arriving so i might as well get things done correctly rather than rushing it, i will get my cables done today, maybe some more paint as well.
:D
holty
Postby holty » Fri Nov 17, 2017 10:45 pm
did a leakdown test today and found 3 leaks, base gasket, inlet manifold and casing, all fixed now, ive also finished the painting, its not brilliant but its meant to be ridden so it will be fine, also couldnt get the plug cap on the plug it was too close to the frame tube so ive sourced a shorter plug and rubber cap, fits now but will be a bitch to change the plug as the exhaust will cover it from underneath.
holty
Postby Fast n Furious » Sat Nov 18, 2017 3:06 am
Perhaps you can use your knees as a temperature gauge? :lol: :lol:
Postby holty » Tue Nov 21, 2017 12:26 pm
Fast n Furious wrote:Perhaps you can use your knees as a temperature gauge? :lol: :lol:
yes , it will keep them warm on a cold day, temp gauge is going in the radiator filler which will go in the hole in the top of the glovebox, ive finished painting, did legshields, front mudguard and both rear runners, ive fitted rear hub and wheel plus flywheel cowling and exhaust, im halfway through fitting runners and mudguard to legshields
holty
Postby holty » Thu Nov 23, 2017 11:06 pm
rh runner board fitted and all the floor channels, not my favourite task, but fitted reasonably well considering the legshields are fibreglass, i had to trim the inside of the legshield rubbers with a knife to get them to go over the edge but turned out pretty good.
then moved onto the waterpump, i needed to mount it in such a way it would move with the engine, so i used a bit of tube to make a clamp which has a pinch bolt on top and it fits over the engine mounting and has a leg welded to it than the rubber mounted pump fastens too, done some plumbing today, its very tight
also got the filler to fit into the hole in the glovebox, will need to find somewhere to put a small expansion tank, and to source a small one, got a cap for the filler with a built in temp gauge
holty
Postby Chadley » Fri Nov 24, 2017 10:49 pm
+1
Chadley
Postby Andy B.L.C. » Sat Nov 25, 2017 1:43 am
Good things come to those wot waits (or so I keep telling myself...) ;)
Andy B.L.C.
Postby holty » Wed Dec 06, 2017 10:52 pm
holty
Postby CHRIS in MARGATE » Wed Dec 06, 2017 11:04 pm
Well done. Sounds good.
Postby dickie » Wed Dec 06, 2017 11:37 pm
Sounds sweet.
You've really taken on a challenge there and from the sound and look of it, you've come up with the goods.
Be proud.
