Got a TS1, with LTH manifold and packing plate fitted.
Using offset cones.
Engine into frame, and got a gap between manifold and frame.... but only about 1mm
Is this enough?
Li3 with Standard Shock length.
foremanbob wrote:first ride on her... apparently 1mm is enough... not frame contact with manifold (well no paint missing...)
dickie wrote:Maybe I'm a fanny but I lift the back end so that there is no weight on the rear wheel to simulate unloading the rear as you come off a lip at speed. If I can pull a bit of paper out then that's enough for me.
