Yet another SIP question
Postby coaster » Sun May 07, 2017 2:12 pm
I beginning to loose the will to live trying the get a sensible reading on my SIP 2 speedo using an external sensor. I have the sensor aligned to pick up the pulse from the front wheel studs and the little blue light flashes off as a stud passes the sensor 4 times per revolution. I measured the type circumference of the tyre (1325mm) and input that figure on screen 3 and 4 pulses on screen 1. The speedo works but seriously under reads. There is a setting on screen 3 that I think is to do with the speedo drive gear ratio but there is no mention of what it should be set for when using an external pick up :?
I tried a few random settings which do seem to affect it but generally make the problem worse :oops:
Any suggestions??
0 x
Re: Yet another SIP question
Postby Storkfoot » Sun May 07, 2017 4:57 pm
No idea, mate. As you know, I do wonder why there are so many threads about problems with these Speedos.
Postby coaster » Sun May 07, 2017 5:09 pm
Storkfoot wrote:No idea, mate. As you know, I do wonder why there are so many threads about problems with these Speedos.
I think most problems are down to the poorly written and confusing instructions all written up in a booklet only slightly larger than a book of stamps :roll:
Postby dave411 » Tue May 09, 2017 5:15 pm
Why not try the pick up that goes into the drive for the speedo cable?
It converts the linear drive into a signal,and that is it.Sounds simple to me.
dave411
Postby Scooterlam » Wed May 10, 2017 11:47 pm
Id guess use a GPS app or satnav to find the margin of error.
Say 50% then increase your wheel measurements by X2 to correct.
I doubt the maths would be that easy but you get the idea
Sometimes its easier to work around a problem than solving it.
Scooterlam
Postby coaster » Wed May 10, 2017 11:54 pm
dave411 wrote:Why not try the pick up that goes into the drive for the speedo cable?
That is a possibility that someone on FB suggested as I now realise that SIP have completely confused the issue by using 2 different external systems.
Postby coaster » Wed May 10, 2017 11:55 pm
Scooterlam wrote:Id guess use a GPS app or satnav to find the margin of error.
Yes, I will give that a go at the weekend
Ta
colin
Postby Fast n Furious » Thu May 11, 2017 4:11 pm
Colin...... If your speedo is registering a speed when the bike is running on the stand then this is typically an RFI problem generated by your ignition.
If I use a Non resistor spark plug on mine, I can make it do 125MPH....... in the Garage!
Just make sure the action of your engine isn't corrupting the display before messing with the pulses per mile setting.
Users browsing this forum: No registered users and 55 guests
