Is this the one
Is this the one
Postby jonno » Sat Mar 25, 2017 6:06 pm
jonno
Re: Is this the one
Postby tim_mason » Sat Mar 25, 2017 8:50 pm
Yes, you will need the fettle the gear changer to fit ,
tim_mason
Re: Is this the one
Postby Simon ELC » Sun Mar 26, 2017 9:58 pm
Simon ELC
Re: Is this the one
Postby jonno » Fri Mar 31, 2017 8:26 pm
I seen to remember someone doing this alteration recently in Show Your Ride? Ive looked at Datz' post and its not there any ideas where?
jonno
Re: Is this the one
Postby Wack » Fri Mar 31, 2017 8:51 pm
Some of the Yam levers are far too long and look odd to me sticking out 2" past the bar ends,these tend to be shorter http://www.ebay.co.uk/itm/Clutch-Lever- ... SwN81WCyUn
Re: Is this the one
Postby Norrie Bodge » Sat Apr 01, 2017 7:53 am
Is there any available for use on a series 1/2 ?
Norrie Bodge
Re: Is this the one
Postby Fast n Furious » Sun Apr 02, 2017 1:32 am
Wack wrote:Some of the Yam levers are far too long and look odd to me sticking out 2" past the bar ends,these tend to be shorter http://www.ebay.co.uk/itm/Clutch-Lever- ... SwN81WCyUn
I agree.... I use a modified Yamaha SR125 lever which is a tad long but it makes for a really nice clutch feel.
Wack.... How much fettlin is needed with that YZ lever?....... I'm gonna try me one of those.
Re: Is this the one
Postby Wack » Sun Apr 02, 2017 3:48 pm
TBH I can't remember as I did one a few years ago. Some have a larger pivot pin hole so I think I used the MB pin but I've also fitted sleeves as well.
Re: Is this the one
Postby jonno » Mon Apr 03, 2017 9:54 pm
Im guessing I could modify the lever instead of the housing,dont want to mess it up before the weekend.
jonno
Re: Is this the one
Postby jonno » Wed Apr 05, 2017 10:20 am
Anyone got a measurement between lever and housing? I nodded the lever but it won't pull in enough to disengage the clutch.
jonno
Re: Is this the one
Postby gaz_powell » Wed Apr 05, 2017 2:22 pm
Norrie Bodge wrote:Is there any available for use on a series 1/2 ?
vespa doglegs go straight on a S2
Re: Is this the one
Postby Knowledge » Wed Apr 05, 2017 3:21 pm
jonno wrote:Anyone got a measurement between lever and housing? I nodded the lever but it won't pull in enough to disengage the clutch.
I think I know which measurement you require, but I don't have one to measure for you as I type. I can see that if you don't modify the lever enough, it will fit, but not pull enough cable. Have a look at the photo on the MB website. They sell the levers with modified housings, and your should look much the same (angle) as those in the photo, even if you have done the modification arse-about-face.
I modded the housing for my new GP last night to the same spec as my current scooter, and it went well, but you do have to remove a surprising amount of material from the housing.
Re: Is this the one
Postby jonno » Wed Apr 05, 2017 8:18 pm
Thanks knowledge Ive found a pic on the Ginger stepchild build,with the amount needed to be removed marked out. Basically the cut is parallel with the handlebar.
Ive messed up the lever btw :lol:,the pivot point is difficult to line up, but £5 is better than £15 to waste. The standard large ball end lever actually is quite good and will stay on for now.
jonno
Re: Is this the one
Postby Norrie Bodge » Sat Apr 22, 2017 6:20 am
i likes the look of these Simon, is it the Lever that needs fettling? the housing? or both to get it to fit??
cheers
Norrie Bodge
Re: Is this the one
Postby Dazts1 » Sat Apr 22, 2017 9:08 pm
Hi ,
It's just the housing to modify so the lever works. It's not difficult just take your time.
Users browsing this forum: Baidu [Spider] and 75 guests
