Under Fresco
Under Fresco
Postby jonno » Thu Feb 16, 2017 9:45 pm
Did the under the kickstart fresco exhaust 1980s model,have a standard type U bend? Im clearing out the shed and need to find the rest of the exhaust . :D
jonno
Re: Under Fresco
Postby rossclark » Thu Feb 16, 2017 10:09 pm
If by standard you mean with a welded in flange then yes.
Usually they would be 48mm diameter and there would be a female sleeve joint where the u bend joined the main pipe.
Re: Under Fresco
Postby rossclark » Thu Feb 16, 2017 10:11 pm
Like this
Re: Under Fresco
Postby rossclark » Thu Feb 16, 2017 10:13 pm
Re: Under Fresco
Postby rossclark » Thu Feb 16, 2017 10:14 pm
Re: Under Fresco
Postby jonno » Fri Feb 17, 2017 10:40 am
Thanks Ross that's just what I needed.Hope I can find it. :P
jonno
Users browsing this forum: Majestic-12 [Bot] and 54 guests
