Piston C type cirlip
Postby Jeff t » Fri Dec 09, 2016 1:59 pm
Just got two replacements and they are slightly smaller so 15mm x 1mm rather than 1.2mm, do you think this is a problem
Jeff t
Re: Piston C type cirlip
Postby Adam_Winstone » Fri Dec 09, 2016 3:05 pm
Personally, I'd never fit the wrong type of circlip, unless it was a 'get me home from a rally' bodge. I've first-hand experience of the wrong circlip being supplied with a new piston, not picking up on the dealer's error and then having it pop out of the piston... abroad :!:
Avoid wrong clips if possible.
Adam
Postby Warkton Tornado No.1 » Fri Dec 09, 2016 3:09 pm
Post by Jeff t » Fri Dec 09, 2016 1:59 pm
I think you must mean nominal Ø16 mm as that is the standard wrist/gudgeon pin diameter.
However, I'd prefer the correct wire diameter simply because there will be more spring rate to keep it in place & discourage rotation/wear.
If you're struggling to find the correct ones, I may have some.
Postby Jeff t » Fri Dec 09, 2016 8:40 pm
thanks for the offer, I'll try one more place tomorrow, the 1mm was the wire thickness and it could be the ones I took out are 16mm but have relaxed to 15mm when I removed them if you know what I mean.
Jeff t
Postby Jeff t » Sun Dec 11, 2016 8:55 pm
Sorted thanks
Jeff t
Users browsing this forum: Majestic-12 [Bot] and 59 guests
