Which size RAMAIR filter for 22mm Dellorto airhose?
Postby davla » Tue Sep 27, 2016 9:34 pm
Which size RAMAIR filter do I need to fit a standard for 22mm Dellorto airhose? I was going to order one off fleabay here:
http://www.ebay.co.uk/itm/RAMAIR-Perfor ... Sw14xWGuxA
davla
Re: Which size RAMAIR filter for 22mm Dellorto airhose?
Postby Donnie » Tue Sep 27, 2016 9:58 pm
MR003 for going on a 22mm hose
Donnie
Postby davla » Tue Sep 27, 2016 10:50 pm
Donnie wrote:MR003 for going on a 22mm hose
davla
Postby corrado » Fri Oct 07, 2016 11:22 am
The ones I've made in the past used a 45mm inner diameter. I used some plumbing tubing [about 42mm] as a bridging piece between hose and filter and used 2 jubilee clips. I found the hose is too soft to fit on the filter directly.
corrado
Postby citydaz » Fri Oct 07, 2016 2:36 pm
Am I right in thinking that longer / bigger filters will allow more air into the carb, to prevent problems such as "bogging" down? :?:
citydaz
Users browsing this forum: No registered users and 48 guests
