Gp crank
Gp crank
Postby gp200ts1 » Sun Jul 17, 2016 8:39 pm
Need a new gp crankshaft for my avanti. Been using a standard crank for the last 9000 miles but it's twisted so in the market for a new one. Nothing expensive but not a cheap Indian one either. Any recommendations?
gp200ts1
Re: Gp crank
Postby Blaginit » Sun Jul 17, 2016 8:53 pm
Af Indian webs with rb con rod is recomended by Ron moss not cheap about £200
Blaginit
Re: Gp crank
Postby bazza3004 » Sun Jul 17, 2016 10:25 pm
If its not going in a ott motor the mec cranks are ok , id swap the rod if higher hp although i used one in an imola with no problems. Glasgow lambretta had some deals on these with bearings and seals not long back may be worth giving them a call.
bazza3004
Re: Gp crank
Postby Knowledge » Mon Jul 18, 2016 1:58 pm
Why not try having your crank rebuilt? If the big end pin is a 22mm version, then you should find a number of suppliers who can build you a crank using a new, tighter pin that will resist twisting.
Try John Howe at Jahspeed.
Re: Gp crank
Postby Scooterlam » Mon Jul 18, 2016 8:00 pm
Scooter Restorations sil with Japanese bearing.
£80 last time I got one.
The rods not pretty but I ran one in my 20+ Avanti with no issues. Also in standard Ts1.
Scooterlam
Users browsing this forum: Google [Bot] and 50 guests
