Egt fitting
Egt fitting
Postby Wack » Sun Mar 27, 2016 10:35 am
Having scoured eBay with no joy, does anyone know where I can get a weld on fitting for an EGT probe that uses an olive and nut to tighten. Thanks
Re: Egt fitting
Postby foremanbob » Mon Mar 28, 2016 7:27 pm
in the states tho... might find more in the uk....
http://www.motorsportsinnovations.com/EGT/egt.htm
foremanbob
Re: Egt fitting
Postby MickYork » Mon Mar 28, 2016 7:38 pm
I seem to think I sourced mine from a hydraulic hose/fitting supplier (Pirtek) ? The outer thread and nut is a tapered stud which help ensures an air tight seal.
Re: Egt fitting
Postby Wack » Mon Mar 28, 2016 9:02 pm
Thanks chaps, I'll try a local hydraulic stockist.
Re: Egt fitting
Postby Stesjh » Sun May 01, 2016 11:51 am
You may want to try Skydrive, it's where I got all mine from http://www.skydrive.co.uk/
Stesjh
Re: Egt fitting
Postby Adam_Winstone » Sun May 01, 2016 12:26 pm
I use these on a number of my bikes and am very happy with them. The weld on fixing and bolt on probe arrangement is very secure, unlike the jubilee clip fitting.
http://www.skydrive.co.uk/proddetail.asp?prod=EP001%2FS
Good company to deal with too.
Adam
Re: Egt fitting
Postby Adam_Winstone » Sun May 01, 2016 12:27 pm
^^^... you beat me to it!!
Re: Egt fitting
Postby Rich Oswald » Sun May 01, 2016 6:06 pm
Stesjh wrote:You may want to try Skydrive, it's where I got all mine from http://www.skydrive.co.uk/
+1
Re: Egt fitting
Postby AlG » Sun May 01, 2016 6:38 pm
Skydrive: +2
AlG
Re: Egt fitting
Postby jonoy » Sun May 01, 2016 9:40 pm
Will this work with a stage 6 guage
jonoy
Re: Egt fitting
Postby Wack » Sun May 01, 2016 10:41 pm
TBH Ive found the Skydrive/Airworld sensors to not last too long, the internal wires break where they enter the probe. Some of the Chinese EBay ones last longer as they have a flexible spring to support the wires like the Stage 6 ones, which if you shop about can be found for £37 for the longer type plus they have the plug already fitted.
Re: Egt fitting
Postby jonashford » Mon May 02, 2016 1:00 pm
anthony tambs of gammatech hes on facebook
jonashford
Re: Egt fitting
Postby Toddy » Tue May 03, 2016 6:06 am
jonashford wrote:anthony tambs of gammatech hes on facebook
+1
Re: Egt fitting
Postby matthew » Thu May 05, 2016 1:53 pm
This is where Anthony Tambs get them from...
http://www.ebay.co.uk/itm/Stainless-Ste ... 1627444040
matthew
Users browsing this forum: No registered users and 51 guests
