Dyno testing
Dyno testing
Postby citydaz » Fri Aug 21, 2015 7:53 pm
Hi,
my mugello 186 Li series III, is having problems spluttering and cutting out.
It starts first time and ticks over no problem, but when I put it in gear it wont go uphill and stalls. I think the timing is shot and the jetting needs adjusting.
Can anyone recommend a good garage in the manchester area where I can get my scoot dynoed and fixed.
(my regular garage is too busy for the next two weeks)
cheers
citydaz
Re: Dyno testing
Postby CHRIS in MARGATE » Fri Aug 21, 2015 10:19 pm
Why don't you check your timing first ? When that's set correctly, then start jetting through plug chops.
With these symptoms I think you'll be spending a lot on remedial work before it gets put on the dyno.
Re: Dyno testing
Postby citydaz » Fri Aug 21, 2015 10:42 pm
Thanks for the advice, just need a garage in the north-west to take it to now.....
citydaz
Re: Dyno testing
Postby amb » Sat Aug 22, 2015 7:37 am
Mike phoenix , Denton .
amb
Re: Dyno testing
Postby citydaz » Sat Aug 22, 2015 11:29 am
Mike Phoenix is my preferred choice, but he is too busy!
citydaz
Re: Dyno testing
Postby Toddy » Sat Aug 22, 2015 1:57 pm
citydaz wrote:Mike Phoenix is my preferred choice, but he is too busy!
Ring him and ask ;)
Re: Dyno testing
Postby citydaz » Sat Aug 22, 2015 5:58 pm
Yes, i did ring Mike - he said he was too busy, which is why I posted the question in the first place
citydaz
Re: Dyno testing
Postby Captain Pugwash » Sat Aug 22, 2015 6:50 pm
Maybe PSL in Kirkby, that's if Mike can't fit you in.
Captain Pugwash
Re: Dyno testing
Postby citydaz » Sat Aug 22, 2015 7:37 pm
cheers
citydaz
Re: Dyno testing
Postby Rich Oswald » Tue Aug 25, 2015 3:36 pm
There's also PSN in Batley, West Yorkshire, which isn't too far.
Re: Dyno testing
Postby citydaz » Wed Aug 26, 2015 10:22 pm
Im booked in for saturday morning at PSL in Kirkby
Early diagnosis is that its a faulty stator
Cheers everyone.
citydaz
Re: Dyno testing
Postby citydaz » Sat Sep 12, 2015 10:15 pm
Got my scoot back on friday from pete at PSL.
Turned out it was faulty wiring in the headset which was shorting out the ignition.
This has been fixed and the scoot dynoed.
16.8 bhp on a mugello 186, but only 68.1 mph?! could swear the speedo once read 80mph!
Its now running really sweet.
cheers all
citydaz
Re: Dyno testing
Postby Jim Rose » Sun Sep 13, 2015 7:52 am
Never trust a Lammy speedo!!!!!!
Jim Rose
Re: Dyno testing
Postby burnside » Tue Sep 15, 2015 12:37 pm
citydaz wrote:Got my scoot back on friday from pete at PSL.
cheers all
That's pretty much what my Mugello does (GPS) with 26mm and Ancelotti clubman. Never trust a Lambretta speedo, my totally standard S2 Li150 often tells me I'm doing 70mph when in reality it struggles to get over 45mph!
burnside
Users browsing this forum: Majestic-12 [Bot] and 53 guests
