JL3 end can on an NK?
Postby ianmoran » Sat Jan 13, 2024 9:26 pm
Hello,
does anyone know if a JL3 end can will fit on an NK pipe? My NK can leaks a bit - loose rivet and there's a JL3 end can available.
ianmoran
Re: JL3 end can on an NK?
Postby Fast n Furious » Sun Jan 14, 2024 2:09 am
These end cans can usually be restored by drilling out any loose rivets and then repaired using new quality 3/16" steel pop rivets.
Postby ianmoran » Sun Jan 14, 2024 12:41 pm
ok, thanks. I might give that a try.
ianmoran
Postby corrado » Fri Feb 02, 2024 1:31 pm
Most bolt end cans are usually easily adaptable to fit other exhausts, either by elongating the holes on the mounting plate or drilling a new set of holes on the plate. The latter an option with 4 stud end can / plates. The one piece end cans / bracket type with rivet on end cans can be converted just by cutting the can off and drilling holes in the plate to accept a bolt on end can.
corrado
Users browsing this forum: No registered users and 35 guests
