Varitronic Ignition....Help!!
Postby HowardS » Sat Aug 19, 2023 5:58 pm
Is there a real idiots guide to cable connections/system installation for Varitronic Ignition? I have fitted the Stator Plate and the Flywheel, but the wiring [no battery model] beats me.........new wiring loom [electronic] from MB.but I still cannot fathom out the connections. The Wiring diagram does not help me....!!??
HowardS
Re: Varitronic Ignition....Help!!
Postby Lord-Spanner » Sun Aug 20, 2023 8:03 am
I might be able to help you when I can get to my diagrams, I had the same issues but eventually got my head around it, but I added a battery, key ignition and 12v dc conversion with a wassell regulator and converted stator plate to my set up, so confused was an understatement, so watch this space ok (unless someone else comes along to explain first) :mrgreen:
Lord-Spanner
Postby Lord-Spanner » Mon Aug 21, 2023 8:39 pm
HowardS wrote:Is there a real idiots guide to cable connections/system installation for Varitronic Ignition? I have fitted the Stator Plate and the Flywheel, but the wiring [no battery model] beats me.........new wiring loom [electronic] from MB.but I still cannot fathom out the connections. The Wiring diagram does not help me....!!??
Did you get a wiring picture with the varitronic kit?
Lord-Spanner
Postby jonw » Tue Aug 22, 2023 8:50 am
jonw
Postby Lord-Spanner » Wed Aug 23, 2023 8:50 pm
Or this one which mine was until I did a full DC conversion..............https://servimg.com/view/19391824/566 (if the link works)
Lord-Spanner
Users browsing this forum: Baidu [Spider] and 14 guests
