missing lynx wrote:A std dc switch should have first position side lights on without engine running second position all systems off third position engine run no lights forth position engine run with side lights and fifth position engine run main lights on. So in position two no electrical things should work.
Warkton Tornado No.1 wrote:I have only ever owned OEM switches of any kind & the UK market battery models always had permanently live supply to horn & brake light.
I would imagine any good replicas do exactly the same![]()
The issue with the standard set-up that many of us used to have was that there was no standard means of isolating the battery so that pillocks could come along & drain the battery by messing with the horn or brake pedal. Hence the fact that keyed or hidden ion/off switches were added to isolate the battery.
This sounds like the opposite of what you are trying to achieve, I know, but still some logic to it. I think.......
missing lynx wrote:Warkton Tornado No.1 wrote:I have only ever owned OEM switches of any kind & the UK market battery models always had permanently live supply to horn & brake light.
I've owen 2 TV200's and an SX200 in my time and all three of them with the key in 2 nd position nothing electrical worked and the scoot wouldn't start
Out of interest - where would you connect the gauges live wire if you wanted them to go live in Position 1???
Screenshot_20220629_131756_com.android.chrome by Kevin Payne, on FlickrUsers browsing this forum: Google [Bot] and 82 guests
