air in carb /fuel pipe
Postby Jamjo » Sat Nov 20, 2021 4:57 pm
Don't know if any one can point me in the right direction I've a tmx35 mikuni on my ts1 and I'm having a lot of problems with air getting in to the fuel line , not just bubbles but lots of air . even when not running and i vibrate the carb i can see a constant flow of air going into the pipe . Any one come across this before as its got the better of me . im worried the flow of fuel will be less than needed to run the kit as ive had a terminal seize previously so reluctant to get out on it without exploring every thing first . long shot but maybe someone would have a solution or some input . Thanks in advance
James
Jamjo
