drive chain tension
drive chain tension
Postby neil64 » Sun Nov 02, 2014 8:45 pm
Hello,
I have a very noisy drive chain, upon inspection there is loads of slack on it , problem is its a 19 x 47 sprocket set up. so not standard gp sprockets. I have noticed a quarter link in the chain which i removed thinking it would tighten the chain, i cannot even get the front sprocket back onto the splinned shaft - any ideas would be great.
cheers neil.
neil64
Re: drive chain tension
Postby Paulnobodyimportant » Sun Nov 02, 2014 9:24 pm
Try this, it will solve your problem.
http://www.granturismo.pwp.blueyonder.c ... sioner.htm
Paulnobodyimportant
Postby bazza3004 » Sun Nov 02, 2014 9:26 pm
Think you need a stretched 82 link chain with 19/47 cogs mate.
bazza3004
Postby Knowledge » Sun Nov 02, 2014 9:27 pm
19 x 47 is a big combination which demands a long chain (longer than 82 link chain).
You make have to reinstate the half-link, and look at a different chain tensioning system, such as a pull-down chain tensioner. These can be combination chain tensioners, that can push-up or pull-down.
If you can't do this, you might need to change your gearing to suit your chain, by fitting 19x 46.
Postby neil64 » Thu Nov 06, 2014 8:43 pm
am i looking at this from the right way . its a 175 stage 3 engine with af clubman and 22 jetex which a think had an 18 tooth on the front sprocket. it felt like reving away but not much actual mph..............?
neil64
